Can a 2"/4" drop be done on a 4WD or just 2WD?
Old Nov 24, 2009 | 10:53 PM
  #46
06LincMarkLT's Avatar
Originally Posted by bankrpt
here you go this is a 4x4 they are doing
http://djmsuspension.com/Articles%20...dF150Drop.html
Is this set up with the Flip Kit and lift hangers? It doesnt mention if this truck has the lift blocks in any of the steps.
Old Nov 30, 2009 | 03:21 PM
  #47
Does anyone know exactly what was used in this project besides the regular 3.5/5 kit? DJM's Tech is telling me that it wont work because they are different, but my Ford Lincoln Mercury dealership parts/service department say the F-150 and Mark LT suspension is identical (which is what I knew, but confirmed anyway). So DJM isnt telling me what was done to that truck to give it that stance, and being a rookie to trucks i cant tell by the write up and pictures. Any help please, im ready to buy and Stylin Trucks is offering me a great quote so far that I really want to take advantage up asap.
Old Nov 30, 2009 | 04:38 PM
  #48
bankrpt's Avatar
Look at my profile my truck is 3.5-5 djm kit get the 3.5-5 kit but get rid of the block in the rear
Old Nov 30, 2009 | 05:30 PM
  #49
is your truck 4WD?
Old Nov 30, 2009 | 05:46 PM
  #50
bankrpt's Avatar
No but I did the same kit on a all wheel drive harley davidson though and we took the block out of it
Old Nov 30, 2009 | 06:29 PM
  #51
How did that 4WD come out, and how low did it go in the back? What size rims were put on? any pictures? Thanks!
Old Nov 30, 2009 | 07:07 PM
  #52
bankrpt's Avatar
He kept the stock harley wheels on it turned out like mine maybe a inch taller due to the tire size difference it looked like this
Old Nov 30, 2009 | 08:50 PM
  #53
Wow thats a dropped 4WD? From what I've heard here it should be much higher. What are those 22's?
Old Nov 30, 2009 | 09:15 PM
  #54
Im planning on the 23" Saleens... Im starting to think the 3.5 in the front might be too low if thats what it does to a 4WD. I could be wrong but seems like I would expect rubbing issues.
Old Nov 30, 2009 | 09:57 PM
  #55
bankrpt's Avatar
i think the harleys come with a 45 series sidewall on 22's if you did a 40 series tire for the 23's they would be the same height
Old Nov 30, 2009 | 10:27 PM
  #56
That would be great, if it doesnt change much with the 23's.... what do you think the difference is between a Harley and a regular 4WD? If you see here on all the different types of kits, they say "Finished height may vary when used on Harley Davidson models."
http://www.stylintrucks.com/parts.as...rtfamilyid=550
Old Nov 30, 2009 | 10:54 PM
  #57
bankrpt's Avatar
Rear kit is designed for vehicles with out factory lifting blocks. Using rear flip kit on vehicles with rear blocks will drop further and require additional parts to achieve desired height.
cause the harleys come with the blocks thats all i can think of i used the djm 3.5-5" kit but my truck is actually 4-6" cause i did other stuff to it my truck being dropped 4-6" and i cant go no taller than a 32" tire with no rubbing so a 285-40-23 tire is exactly 32" tall so you will be ok
Old Nov 30, 2009 | 11:07 PM
  #58
But all 4WD's come with the blocks. i have 2" blocks
Old Nov 30, 2009 | 11:19 PM
  #59
bankrpt's Avatar
Remove the blocks because if u leave them in the u will end up dropped 3.5-7"
Old Dec 1, 2009 | 07:53 PM
  #60
See thats where I get confused.... this is how I see it in my head with this particular DJM kit (3.5/4).... take out the blocks 2" drop + 6" Flip kit = 8" drop + 2" Lift Hangers = total of 6" drop when finished (too low I think?)
Am I doing this right? I 'm going with the lift hangers to acheive a total of 4", so if I leave the 2" blocks in that will add the 2" that i need for a 4" drop when finished.
