Can a 2"/4" drop be done on a 4WD or just 2WD?
4wd and 2wd use same springs front and rear. Front the strut is longer, rear has an additional 2" lift block. So if he did a 6" flip kit in the rear he would have to leave the 2" block out and it would be an 8" drop for him.
I think you can't go more then 4" up front due to the CV axles.
Carry on
Carry on
easiest way to drop the rear of your truck 4" from where it sits right now would be 2" shackles and remove the 2" lift block and use 2wd U bolts.
and easiest way to drop the front will be putting 2wd spec struts on your truck
I am looking at his list. He has the 6 inch flip and the 2 inch shackles and the 2 inch glocks removal. That is 10 inches of drop right? Are they. Selling him the shackles and he doesn't need them? I think he is getting a lot of drop there that the truck can't handle. Or is my lack of knowledge of flip kits confusing me? Or the lack of sleep just starting my knight shift week with a 3 year old at home who doesn't.care that I need sleep.
It uses the factory springs. The wheels are the 23" Saleens. Im getting the DJM kit, here is whats included(quote from Stylintruckes.com...
DK7136 Lowering Kit - 3.5 Front / 5 Rear Each
CA3205L3 Lower Control Arms - 3 Inch Drop Pair
FK32046 Rear - Flip Kit - 6'' Each
SH3200 Rear - Shackle Kit - 1'' Lift Set
2200DJM Cal-Max Super Shock Each
Carry on
Carry on
If you leave the block in with the flip kit it adds another 2" drop
Trust me, if you want to go 2/4 from where you are right now, just do 2wd struts up front, and remove block and add a 2" shackle in the rear.
I want to go 3/5 from where i am right now. If i remove the blocks with the flip kit then what?
it would be a 3/5 +2 block removal for total of 3/7
if you left blocks installed, it would be 3/5 +4 for a total of 3/9
Okay if you want 5" rear drop do 3" eibach leafs combined with 2" block removal
Ok, I googled F150 block pics and then went out side to look. i do have blocks. So one option to get the 5" drop would be what Patman said to get the 3" leafs and remove the blocks. Other than that any other options or kits out there to get the 5"? Im still going with the DJM 3.5 front drop.
I have the Saleen suspension on my truck which is advertised as a 2/2 drop if you leave the oem 2" blocks in and 2/4 if you take them out. The kit consists of new coils, new leafs, new struts and new shocks. I have an H&R kit too that been sitting in my dining room for a couple months. That kit consists of 2" lower coils and 1.5" shackles. I decided that I'm going to cut 2" of dead coil off of the H&R springs and take the Saleen's out along with installing the shackles. That'll give me 4/5.5 of drop and leave about 2" of gap above my 33"+ tires. Take a look at my current pics to see what the 2/4 looks like and adjust from there.
Sorry for the late entry
the blocks will be between the leaf spring and the axle
your other option is doing 3" leafs, and a 2" shackle and leave the blocks in, but it will cost more and be softer riding which means you will loose more payload
