removing a leaf
your truck has a flip kit right and your flip kit came with a set of shackles right? if so those are lifting shackles change those out and install your factory ones and there is another inch of drop
i removed my bottom leaf and it dropped mine 1 " ... you can definately tell with a full tank of gas...it bottoms out on a couple of bridges here locally... i have 2" drop shackles also.. and the ride is a little less stiff... but now i want 2" mnore inches!!! it never ends..
already have done that that how i got down 6" then lifted it up .5" with the coil overs, if i went lower with them the coils would be too loose and wouldnt be good, hard to explain but if i took out a leaf that would put more weight on the coil making it work better
trust me i would if i could, along with some new coils for the front for another 1-2" of drop
and i like the ride, stock it seems way too soft and bouncy
