Finished the Eibach 2-3 kit.
Old Aug 4, 2008 | 01:21 PM
MXrob26's Avatar
Wow, both of your trucks look awsome. And If i were you, I wouldnt lose the running boards. I like them.
Old Aug 4, 2008 | 01:32 PM
Who, me? mine are already off.
Old Aug 4, 2008 | 02:29 PM
OgRedd's Avatar
Originally Posted by Stealth
My favorite color is black. It's staying . The hailstorm happened while I was at work, no possible way to protect her. Sickening to watch. I didn't see the truck getting hit, since I park like 300+ yards from where I work in the plant, but I knew it was bad.
In addition to the drop, I'm considering HD emblem and stripe removal. But then I think why. I bought the HD because it's a HD. But then I love the all black myself. Confused. - Og
Old Aug 4, 2008 | 02:54 PM
I'd leave it as is and just drop it. Everything can be put back the way it was if you don't like it.
Old Aug 4, 2008 | 11:26 PM
b-dub's Avatar
abelrob,
Your truck looks sharp! Besides the kits components, did ya change out your shocks? I'm lookin for the same set up and I'm tryin to do all my homework first. Thanks.
Old Aug 5, 2008 | 01:31 PM
OgRedd's Avatar
So true. That's why you're a moderator! - Og
Old Aug 5, 2008 | 02:00 PM
I've kept all of my stock stuff just in case.
Old Aug 5, 2008 | 09:14 PM
RumblinF150's Avatar
With 2" drop coils are any other parts needed for a proper alignment? Around here the only thing stopping me from lowering my truck is there are no reputable alignment shops here!
Old Aug 5, 2008 | 09:15 PM
My truck aligned fine after adding 2" drop coils. I had it done at NTB.
Old Aug 6, 2008 | 06:06 AM
OgRedd's Avatar
No need for alignment keys? - Og
Old Aug 6, 2008 | 10:20 AM
abelrob's Avatar
Originally Posted by b-dub
abelrob,
No, I didnt get new shocks. Im a little curious to see how the ride is with some quality drop shocks? I havent taken the truck to get aligned yet, but it drives straight.
Next up is painting the taillights and all of the emblems with the nightshades smoke clear paint. The truck will be completely blacked out except for the chrome lip on the wheels.
Old Aug 7, 2008 | 07:53 PM
b-dub's Avatar
Nice! Get the pics up ASAP! Thanks for the info.
Old Aug 7, 2008 | 10:54 PM
ST Grey's Avatar
The ride is stiffer than stock, as stated by abelrob, but is fine. I think since you're using just the 3" leafs out back you shouldn't have any vibrations, but I could be wrong. I did a 4" drop with GF shackles/shims and the leafs, so I had to do a carrier bearing relocation bracket, one that raises the carrier bearing, since I have a 2 piece drive shaft.
Stealth, do you still have the stock shocks installed on the front? Right now I have the back lowered with 2" shackles/shims and Belltech 0-3" lowering shocks. I still would like to go lower all around though. I was just debating coils or spindles for the front. Does your truck seem to corner better with those springs?
Old Aug 8, 2008 | 02:00 AM
Yes, I'm still stock shockwise up front, but with a 2" GF drop coil in each. It seems to work fine, it's a little softer than the rear with the Eibach leafs and GF shock combo, but it's OK. I'd like to go with Eibach shocks all the way around soon.
It corners great. Of course the 22's with 40's helps too.
Old Aug 9, 2008 | 06:23 AM
02LayinThem24s's Avatar
Thumbs up
slam it!! then lift up as high as you want when you drive it. haha!
