anyone running traction bars or a panhard bar?
Old Jun 8, 2008 | 07:49 AM
Veteran: Army
like the title says I am wondering if anyone is running traction bars or a panhard bar or both.
my green truck is having traction issues and I am considering a set of JLP traction bars with a panhard bar or just the panhard bar.
truck is a 2001 F-150, lowered 1 inch up front and 2.5 in the rear. Running stock lightning front coils and '03 lightning rear leafs with beltech 2 inch drop shackles.
Old Jun 8, 2008 | 08:17 AM
wfin2004's Avatar
I don't have any problem with traction. Although I accelerate like there is an egg under my gas pedal. Trying to reduce fuel consumption, ya know what I mean? I guess if you are in the market for Trac Bars, fuel consumption is not an issue for you. But well, it should be.
Old Jun 8, 2008 | 08:35 AM
Veteran: Army
the truck gets around 25 on the highway and about 12 in town (when driven nicely) but when I mash the loud pedal it get's into a wheel hop when the tires are spinning
just trying to figure out if the traction bars are going to affect the ride or cornering
Old Jun 8, 2008 | 10:11 AM
wfin2004's Avatar
I couldn't tell you if mine could spin the tires or not. How much HP does the stock 5.4 have?
I have had a lot of Fords, and it has seemed that all them had some form of wheel hop issue.
Old Jun 8, 2008 | 10:42 AM
Veteran: Army
the stock 2 valve makes around 260 hp at the flywheel, the ATI is pullied for 12psi, with MAD's intake and a racing bypass valve so it makes a bit more power now. It also has a 2003 Lightning rear anti-sway bar.
I am also considering going swapping to Harley truck front springs to tighten up the front end.
I know the traction bars will help elminate wheel hop but will they tighten the truck up and make it rough on corners?
Old Jun 8, 2008 | 10:54 AM
breoland's Avatar
hey man, been talking to a few people and they said swapping the passenger side shock to face twards the front of the truck is a quick easy fix for the wheel hop. I already found a set of mounts from a lightning. as soon as i get them and make the switch, i'll let you know how it works out
Old Jun 8, 2008 | 12:05 PM
Veteran: Army
the harley truck has the eaton and it doesn't wheel hop just that blasted non svt suspension on the green truck
with long traction bars I have to keep the shocks facing the rear of the truck anyway
Old Jun 8, 2008 | 05:08 PM
IR0NS1N's Avatar
How good are the tires on your green truck? Also, I would look into 54" traction bars for ur truck. I know they make them for the l's and I believe they fit all trucks of that older bodystyle.
Old Jun 9, 2008 | 05:08 PM
Veteran: Army
I'm thinking I might try the panhard bar first then if that don't work I'll add the long bars from JDM.
I wish Tim Skelton would chime in here
Old Jun 9, 2008 | 08:58 PM
IR0NS1N's Avatar
I would try like http://www.nloc.net/ and see what they say.
Old Jun 13, 2008 | 12:32 PM
Veteran: Army
well after searching around I decided that I am going to get some upgraded sway bars (hellwig) Harley truck front coils, upgraded shocks and a panhard bar. Then if needed I'll add the traction bars.
Old Jun 13, 2008 | 01:07 PM
boss1984's Avatar
i used to have some major tire hop..then i ordered traction bars from Summit
Racing and the hop is 100%gone..best $110 i spent on my truck
Old Jun 13, 2008 | 01:25 PM
Veteran: Army
did the traction bars improve the cornering as well?
Old Jun 13, 2008 | 01:55 PM
boss1984's Avatar
yes it did it helped some of the body roll go away..but the tire hop was most improved
Old Jun 13, 2008 | 02:11 PM
Veteran: Army
good news, thanks
what traction bars do you run?
