Lets talk about the airide kit
Old May 29, 2007 | 10:40 PM
troberts6874's Avatar
Old May 29, 2007 | 10:55 PM
flareside4life's Avatar
Originally Posted by troberts6874
hell yeah alot lower than that....i have seen the 97-03 model truck tuck 26's and lay frame...but that is serious rear notch/bed cut and front inner fender cut out...you could prob tuck 20's with rear notch only not cutting into the bed or front inner fender and get less than 3 or so inches frame to ground.
Don't forget the body drop so the body still isn't 4 inches off the ground
Old May 30, 2007 | 12:01 AM
1fast4.6's Avatar
oooh body drop... thats pretty labor intensive isnt it?
i basically wanna go as low and level as possible without punchin a hole in the floor of the bed
Old May 30, 2007 | 09:21 AM
yeah body drop is alot of work...would guess atleast 80+ hours of fab work....but to take up the frame gap to body gap to ground they make those thingys called rocker pannels....they will help you cheat a bit to look lower.
Old May 30, 2007 | 04:25 PM
Yeah a ground effects kit with side skirts helps you cheat, a lot. Also, it doesn't involve losing 2-3 inches of head room in the cab.
Old May 31, 2007 | 12:50 AM
Ok, today I called airride and recieved some useful information,
1. Load capacities on an airbar setup meet stock specs. No loss of towing or payload capacities.
2. They use firestone 2 layer bags, which have an expected life (with proper installation of 30+ years)
3. Rise times with a single 5 gallon tank and vair 400 compressor with 3/8 line are around 3-4 seconds.
