How much Dynomat?
Old Sep 3, 2002 | 05:30 PM
goat's Avatar
How much Dynomat?
I want to cover the 2 front doors and all of the back seat area. I was thinking about not doing the floor. How many square feet do you think I'd need?
Old Sep 4, 2002 | 11:50 PM
Deus's Avatar
http://www.raamaudio.com
Cheaper than Dynamat and just as good. Try 1 roll.
(I am not associated with Raam Audio)
Old Sep 5, 2002 | 04:25 PM
2000FordStyle's Avatar
goat
Just like Deus says. Try the RAAMmat. Its a 50 sq ft roll or 62 if you get the 60 series. It should be plenty to do the doors and all the rear seat area with one good layer. I purchased 2 rolls of the 60 and got 2 layers on it all and it really works to dampen the sounds/vibrations
Old Sep 12, 2002 | 01:52 PM
F150NKY's Avatar
Registered User
To ask the opposite question, how little Dynomat.
The stuff is expensive (no matter which brand I use). Is using a small amount (10" square) around each speaker enough to even make a difference.
I use the 10" square size because I found this size for $5.00 a sheet.
Old Sep 22, 2002 | 11:51 PM
Hazard269's Avatar
use none of the above...try storm guard...at homedepot 200 sq ft for 40 to 60 bucks....its all the same some is just thicker....and if thats the case just double layer storm guard....
use a butane torch to get it to stick inthe hard to stick places
-Chris
