Anyone put 12's in a...
Has anyone be able to fit 2 12 inch subs behind the seat of a regular cab f-150? I tried 2 years ago and couldnt do it, but then i had no idea what i was doing... So has anyone else tried it? I currently have 2 10's behind my seat and it is cutting it close... thanks
If you're going to be tight on space, check out the diamond audio M5 12's at diamondaudio.com. They work great as long as you have at least .70ft³. Although air space and power are inversely proportional so you'll need a lot more power with the lower space
I have a 12"MTX behind the seat of my truck now. It's tight, but the box has 1.3^3ft. Its 24" wide, so I could do 2 12's w/o a prob. Actually I am considering using a box 48" wide, slot ported for a DD 3512 with 600w or so. That will really rattle your fillings!
Personally I wanted 3 12" JL's in my Lightning, the Lightning I don't yet own....but I don't forsee a problem with gettin 2 12's in there, especially if u do some fiberglass work and make the box tall like the thunderforms, you should have problems gettin enough airspace so long as you use the right subs, like solobarics or w3's that don't require as much airspace....
You'd be bettter off with a W0 if space is a problem...the W3's want 1.25^3 ft. sealed. To hell with it, just do a single ported 10" or 12" and save the money and feel the difference.
Theirs only about a 3 db gain with every additional sub, and that's if you feed that additional sub an equal amount of power instead of adding it to the existing amp.
(...unless the addition of the extra sub lowers the impedence load on the amp, thus doubling it's output, assuming it can handle the lesser resistance.)
-AR
Theirs only about a 3 db gain with every additional sub, and that's if you feed that additional sub an equal amount of power instead of adding it to the existing amp.(...unless the addition of the extra sub lowers the impedence load on the amp, thus doubling it's output, assuming it can handle the lesser resistance.)
-AR
Polk Momo's can use an insainly small space......and handle a lot of power. I run a single Polk DX 12 behind one seat.....I think I have a .75ft^3 box (getting ready to build a new one). As for the amp(s) - they go under the seat really nicely!
Robbie
Robbie
I put two 12s in tonight actually. =) Used the MTX thunderform, and modified it out for the 12's
look pretty slick, and with teh bracing i added it doesnt flex to bad!
I'll take some pics as i am suire some of you all are interested already =)
BTw i used plk gnx 124's
Brandon
Brandon
I installed two 12" MMATS DVCsubs in my reg cab..i just built the box as large as i could for now..not sure of the dementions ..probably going to build a better box soon, i've almost blown this one apart by now..,
I was thinking about putting 2 Audiobahn Aw1200x's behind the seat... Im not sure of the air space needed, so if anybody knows can you please let me know? Also any of you guys who have 2 twelves can you please show me some dimensions and/or pictures... THANKS
I think they were around 1.0-1.2cu.ft each sub. Watch out you have enough depth to mount them in the box and don't forget you'll need at least 1.5 to 2 inches space so the vented pole piece can breath on the top of the magnet assembly.
Audiobahn used to have all the sub specs on their website. Can't find it anymore. Time to complain!
