Jl10w3 ??
Old Jan 3, 2002 | 12:37 PM
sjLightning's Avatar
Jl10w3 ??
In regards to the standard cab(L) are the Thunderforms adequate for the 10W3's or should a custom enclosure be made?
I know many have chosen the Thunderform enclosure - were you satisfied or do you believe MORE performance can be achieved w/ a custom enclosure.
After doing some research I see the box can be bought for $218 or so..
How much do the 10w3's cost & where can they be ordered??
Old Jan 21, 2002 | 02:09 PM
expy02's Avatar
be careful, i could only fit a w0 in my stealth enclosure for my 02 expy. be sure to check the specs on both the box and woofer
Old Jan 21, 2002 | 03:36 PM
btolenti's Avatar
try www.thezeb.com or www.matrixaudio.com.
According to JL, the mounting depth on the sub is 5.8125 inches, and it requires 0.6 to 0.9 cu ft. of airspace per sub...
The thunderform, according to MTX has an enclosure volume of 1.8 cu ft.....or 0.9 per sub, just on the edge of what the W3 works with. This should allow the sub to play deeper, but with less accuracy.
The only problem I can foresee is a mounting depth problem. The Thunder 6000's, what the thunderform is designed for, have a mounting depth of 5.125 inches. So there seems to be a ~3/4" discrepancy there. Has anyone with a thunderform measured the allowed depth?????
If not, call MTX and ask....
MTX
4545 East Baseline Road
Phoenix, AZ 85042
602-438-4545
800-225-5689
Tech Support email, use the following link:
http://www.mtxaudio.com/caraudio/contactWedge.cfm
Hope that helps...
Old Jan 22, 2002 | 08:49 PM
Thumbs up
THANKS for the specs/info.....
Old Jan 22, 2002 | 10:39 PM
btolenti's Avatar
No problem.....man, I love this car audio stuff!!!!!!!!
