Size Question
Old Nov 27, 2001 | 10:51 AM
Jxtreme's Avatar
Question Size Question
I was wondering what sizee the door speakers in the 2001 F150 was. Is it a 6x8, or is it a 6.5? BTW what size are the ones in the rear?
Thanks any help would be great.
Old Nov 27, 2001 | 11:11 AM
rtroha's Avatar
6x8
I'm pretty sure that they are 6x8 in both the front and rear. At least that's what my 2000 has.
Bob
Old Nov 27, 2001 | 03:42 PM
bcam04's Avatar
they are 6x8 in my 98 but i replaced them with 6 1/2 alpines so the 6 1/2 will probably fit if thats what you want to put in
Old Nov 27, 2001 | 06:08 PM
haze10's Avatar
01 HAS THE 6X8. A direct replacement would be another 6x8 or the 5x7. both have the same basic frame size. A 6.5" round, will need a spacer plate, or some panel cutting to fit. 5.25" will fit without cutting but you still need a thin mounting plate.
Old Nov 27, 2001 | 06:14 PM
PhillipSVT's Avatar
bcam04
which Alpines do you have? I was thinking about replacing all 4 speakers in my truck, and mabee a 10" R or S. Do the alpines sound much better than the factory ones. I am also thinking about an alpine amp, so everything would be ////Alpine
Old Nov 27, 2001 | 09:18 PM
bcam04's Avatar
phillip,
i have a 2way 120 watt(30rms) the only thing resembling a model is sps-1629...they sound great!! and i assume you are going to replace the factory stereo also b/c i think that helps a little also... i like it loud and you can hear them great going down the highway which was the goal i had in mind when i bought them
(i bought them for my car which i wrecked and didnt feel like buying yet another set) but i am happy with them and i have had them for about 7 months if you add a sub and an amp it should be thumpin'
good luck
brent
Old Nov 27, 2001 | 11:27 PM
sundog7's Avatar
Buy components for the front stage if you can budget it. You'll be glad you did. MUCH cleaner sound that you can crank till you ears bleed, properly amped. I would suggest you spend your hard-earned money on your front stage/amp first and leave the back alone for now. I replaced both front and rear in my SCrew with comps in the front, and coax in the rear. I may as well have not touched the back. THe front stage is so clear and powerful, I just can't hear the back. I'm going to rip out the nice 6.5 rounds I put in back and replace them with a good set of midrange or tweets -- just something to give a little added brightness and fill.
