Kicker Substage replacement for Sony sub
I have a 13 model platinum f150 with the sony sub underneath rear seat. I have picked up a 10" Kicker substage upgraded sub that was offered as an upgrade years ago when these trucks were hot. Unfortunately I don't have the harness that is required to put into the truck. I have reached out to Kicker for help and haven't received anything yet but was wondering if some of you on here may be able to help on what's what on the wiring colors to get the kicker installed. I don't mind splicing since the harness is likely not available anymore. My kicker has the small black amp attached to the box. pretty sure it is 9L3J-18C804-AB Ford part # but a couple number/letters are almost not legible to make out. I appreciate anything you fellas can send.
