Amp questions
Old Mar 29, 2014 | 07:24 PM
FX4Matt's Avatar
Amp questions
Hey all, just wondering if this amp http://www.pioneerelectronics.ca/POC...eries/GM-D8601 would be good to power 2 of these http://www.pioneerelectronics.ca/POC...ount/TS-SWX251
Thanks in advance
Sent from my iPhone using IB AutoGroup
Old Mar 29, 2014 | 09:52 PM
pizzaman711's Avatar
That amp should match up okay, the amp does 500 rms at 2 ohms, and the subs together can be wired to a 2ohm load and according to the specs will take 100-400rms.
You could go with a smaller amp too that'll do 400rms at 2ohms and you'd be okay, and it'd save you a little money.
Old Mar 29, 2014 | 10:35 PM
01 gt f150's Avatar
500 watts @ 2 ohms divide x 2 = 250 watts per speaker RMS. Voltage remains while current (watts) divides at the split.
Old Apr 1, 2014 | 11:52 PM
TK5's Avatar
TK5
Thanks in advance
I would say that is a good match. Amp will put out 250 watts rms to each sub & the nominal power handling of each sub is 200 watts. Perfect match in my book.
