sub box/rear seat
Old Mar 9, 2014 | 02:30 PM
cwking25's Avatar
Fox box doesn't come in a ported enclosure for a 2004 Supercab, at least that's what they told me when I called them, I think its only for the newer style trucks
Old Mar 10, 2014 | 12:00 PM
shanecaseber's Avatar
[IMG][/IMG]
Originally Posted by cwking25
Shane, you have any pics of the box? Also did you build it yourself or have a shop do it?
Yes I made it my self to fit 3 sealed 2012 type r 12'' its nothing fancy it just fits the floor tight the sub face down about 6 inch off the floor and it stretches across the cab .Their a back rest I made as well framed out Plexiglas to see the amps .But its not in on this photo
[IMG][/IMG]
Old Mar 10, 2014 | 10:24 PM
cwking25's Avatar
looks good man
Old Mar 11, 2014 | 10:53 PM
Why do you have 4 amps?
Old Mar 11, 2014 | 11:13 PM
pizzaman711's Avatar
That's what I was thinking too..
Old Mar 12, 2014 | 06:33 AM
Why ? running bridged full range 1 amp front. And bridged 1 amp for mid only rear .Independent the last 2 Mono Amps for each of the 2 subs. I will soon be adding a Kicker Front Row DSP and may run active plus time alignment for the front sound stage .And just have more control over the rear fill and or surround .
Old Mar 12, 2014 | 09:00 AM
To me, it would have made more since to sell off the original amps and get two amps, one for the subs, one for the components. But that's just me I suppose. Also what do you have up front to be able to run full range and still hit the lows?
Old Mar 12, 2014 | 12:32 PM
Just a preference on the amps l wamted to fill the wall up .well not true full range up ,subs do the lows but l am surprised how deep the new style 6.5 alpine comps reach
Old Mar 13, 2014 | 01:29 AM
I figured part of that was for looks. It does look cool, especially with that double 0 or whatever coming out of the wall. I just couldn't mess with all the wires! That's why I'm not real inclined to amp my doors, even though I'd like to when I get some that can handle more power.
Old Mar 13, 2014 | 06:45 AM
Yeah that's all That is 1x 0 gauge on top going in to a fused distribution box that displays amps and volts draw in blue LED with 4 x 4 gauge coming out of the bottom.To feed the amps .I did the up grade on my electrical system to keep up with the demand .
Old Mar 13, 2014 | 02:36 PM
I'm surprised that one run of 1/0 can keep up with all those amps. What are those amps rated at?
Old Mar 13, 2014 | 07:48 PM
A HQ 1/0 like the Kolossus Fleks Kable I ran can handle over 300 amps about 320 max I would say . And I am only pushing about 230 amp range I have never seen my voltage very rarely drop below 14.2 volts.No matter what I throw at it I haven't even blown a fuse in 5 years
Thanks in part to my Odyssey Battery the big 4 and a 230amp H.O alternator . And my gains set properly. Alpine MRP amp lines are pretty efficient as well . At one time
I was running 2x MRP-M1000 and the 2x MRP-F300 4 ch . and it could keep up with that. I only down sized cause theirs no need for 2000 watts for truck subs .
Old Mar 14, 2014 | 01:39 AM
Damn, that's a lot of upgrades and fancy gizmers haha. Sounds cool though!
Old Mar 14, 2014 | 02:38 AM
You have some great electrical to back it up, so that definitely helps. Are you running dual or single batteries?
Old Mar 14, 2014 | 06:17 PM
Just one. odyssey PC1750/65 AGM is a beast of a battery. Fast discharge and recovery. I never would run my system with out the truck running .So I just don't see the need for 2 batteries. .................................................. .................... The days of sitting at the park with my windows down blaring the Jensen tri axle's with the Kraco power booster with my GF mixxtape . Waxing the car with it turned off . Are long gone. LOL You young guys would not remember that gear back in the day .You would run your power and ground wire in 22 gauge to tap a fuse lol If you wanted some kind of sub you hooked up your parents 2 way HI-FI home speaker with a giant 15 inch paper cone speaker and walnut enclosure. And tossed it in your back seat . Trunks where for beer coolers and kegs only !!
