Sub woofer question
Old Jan 20, 2013 | 03:45 PM
eastern sierras's Avatar
Sub woofer question
I just installed Memphis audio to replace the Sony speakers. Are the sub 2 or 4 ohm? I'm looking to replace the stock one with a Hertz 8" shallow.
Old Jan 21, 2013 | 01:16 PM
anyone?
Old Jan 21, 2013 | 01:44 PM
Ray21's Avatar
The stock sub? Not sure what impedance it is... pull it out and see if its printed on there or check it with a DMM.
Old Jan 21, 2013 | 07:22 PM
pizzaman711's Avatar
I doubt the stock amp will have the clean power and amount of power a Hertz sub will want.. I think you'll have to end up adding an amp anyways so I wouldn't worry too much about impedance but if I had to guess its probably 4ohm.
Old Jan 22, 2013 | 10:02 AM
Thanks for the info. After thinking about it, I'm going to redo the whole thing. I'm pulling the MA speakers I just put in and I'm going with German Mastros in the doors, a Hertz Sub and Hertz amp.
Old Jan 23, 2013 | 02:18 AM
I like the way you think when you redo things haha. You'll definitely be impressed with that setup over the MA speakers and even more over stock. Keep us posted on the install!
