Amp Rack
Old Nov 13, 2012 | 02:47 PM
MikeyDubs's Avatar
Amp Rack
I'm in the process of doing a system in my 06 super cab. I'm doing a 10" sundown SD2 in a foxbox powered by a Alpine M500. I will also be doing Cadence 6.5 components up front and cadence 6x8s in the rear powered by a Alpine F300. I already ran all the RCAs, spreader wires and my 0 gauge so when I get the Alpine f300 I will be able to hook everything up. So I'm looking for some input,pics and ideas of ppl that have done a amp rack behind the rear seat.
Old Nov 14, 2012 | 12:02 AM
TK5's Avatar
TK5
Check out my album for more ideas. Installed in a 2006 SuperCrew.
Old Nov 14, 2012 | 08:34 PM
MikeyDubs's Avatar
Great Thank you TK5! Do you mount MDF first? If so what do you use self tap screws to screw into the sheet metal?
Old Nov 14, 2012 | 11:57 PM
TK5's Avatar
TK5
Sound deaden back wall
Fill in gaps with sound absorbing closed cell foam
Add 1/4" thick hard board with a few self tapping screws, add a dab of silicone to screws to seal any potential leaks
Cover with sound deadener
Add amp of your choice
If your amp board is too thick, the rear seat will rub on your amps.
Old Nov 15, 2012 | 12:05 PM
MikeyDubs's Avatar
Great thanks!! What size self tappers did you use and what size screws did you use to hold your amps?
Old Dec 2, 2012 | 03:42 PM
TK5's Avatar
TK5
Talking
Any more progress on your system? Please post some pics if you don't mind.
[IMG][/IMG]
