2001 System Audio question
Old Jan 23, 2012 | 01:56 PM
tschaffer's Avatar
http://www.sonicelectronix.com/item_...ch-P300-2.html
or http://www.sonicelectronix.com/item_...M-GTX1302.html
with
[url]http://www.sonicelectronix.com/item_33494_Kenwood-eXcelon-XR-W10F.html[url]
using premade box
http://www.supercrewsound.com/97F150ECsingle.html
I should be able to run that sub with that amp bridged without causing any issues? I've never done a system at all before and want to make sure before I order that I have most of my specs matched up! Thanks!!!
...willing to take suggestions on equipment
Old Jan 23, 2012 | 03:47 PM
pizzaman711's Avatar
Links aren't working. But stay away from kenwood amps, the quality is horrible and they don't do near the power they state.
Old Jan 23, 2012 | 04:59 PM
tschaffer's Avatar
http://www.sonicelectronix.com/item_...n-XR-W10F.html
Old Jan 23, 2012 | 08:25 PM
Good choice on the rockford amp, they're great quality and generally underated power wise too.
I wouldn't touch that sony amp though, again like kenwood stuff they're generally bad news and won't perform nearly as good as they say the will.
The box is good as long as you can get a sub to match the specs of it, custom boxes are usually the best because you can build them to exactly what you need but prefab ones can work some times.
Old Jan 24, 2012 | 10:33 AM
tschaffer's Avatar
The last link is the sub I was planning on using, by my rough look that should work with the box space right?
Old Jan 24, 2012 | 11:11 AM
tschaffer's Avatar
also considering using http://caraudiofactory.com/20012003-...ngle-p-60.html
also considering http://www.sonicelectronix.com/item_...10-D4-V.3.html for sub
Old Jan 24, 2012 | 01:15 PM
DEFINITELY get the Image Dynamics sub, they're great little subs. There's no comparison between the ID one and the kenwood sub, it really is that much better.
As for the boxes either one would work for the ID sub.
Old Jan 24, 2012 | 02:30 PM
tschaffer's Avatar
Went with the ID sub, Rockford amp. Going to bridge I think power should be good, also went with the downfiring box...look forward to getting it!
Old Jan 24, 2012 | 02:33 PM
tschaffer's Avatar
Thanks for all your help!
Old Jan 24, 2012 | 04:16 PM
Not a problem at all! I think you'll definitely be impressed with that setup!
Old Jan 24, 2012 | 07:59 PM
Uncle Jesse's Avatar
i love my Image Dynamics sub..dual voice coil..great quality...
