Door Speakers
Old Apr 9, 2011 | 10:15 PM
  #31
ab46501's Avatar
Thanks Scott... I've been searching around. What do you think of those speakers with a new HU and then a sub? How do I pick out things that all match properly? I would think like I 10" sub under the rear seat, but I have no idea how to install an amp. I see you have them in your truck
Hey John,
That would be a big improvement over what you have now. Those speakers, a new HU, amp and sub and you'd have a very good sounding system.
Crutchfield is a great resource. I've bought from them many times and they have the best customer service.
Sometimes they can be overpriced though so check around.
Wiring amps are not hard at all. Just a little wiring required.
Old Apr 9, 2011 | 10:27 PM
  #32
ab46501's Avatar
As far as matching a system it's not hard either. If you are going to run the speakers of the HU then go with a basic low power sub so not to overpower. 200 watts rms would be plenty. I'd probably recommend getting a 4 channel amp though. Run the front speakers and sub off the amp and the rear off the HU.
Old Apr 10, 2011 | 04:45 PM
  #33
Thanks for that Scott! I am going to try to figure out what to get. I may try to see if I can find some lightly used stuff
Old Apr 10, 2011 | 09:39 PM
  #34
Shanks12's Avatar
Originally Posted by ab46501
I'm not sure how the audiophile is set up with the tweeters, it may already be spliced for you. If not you could splice them in as long as the crossover is still connected.
You may not even miss them though once you get new speakers.
Okay thanks man.. I gotta figure out which set I want and get them installed
Old Apr 10, 2011 | 09:41 PM
  #35
Shanks12's Avatar
Originally Posted by Blue07STX
Kenwood's are better than Pioneer's. My Kenwood's are 91 db, 2-55 W RMS, two-way coaxial, KFC-6879ie. I purchased mine new from Amazon. Crutchfield recommend's using 90db or better with factory HU's.
The ones I was looking at are 3 way... Whats the big difference in 2 and 3 way?
Old Apr 10, 2011 | 11:40 PM
  #36
RES4CUE's Avatar
Woofer and 1 tweet or woofer and 2 tweets.
I got the Inifnity Kappa's in all 4 doors, they sound great, run off a Kenwood DDX616 HU
http://www.amazon.com/Infinity-6829C...2493152&sr=8-1
Old Apr 16, 2011 | 02:28 PM
  #37
Shanks12's Avatar
Originally Posted by Shanks12
I was torn between using the Kenwood KFC-C6893PS and Pioneer TS-A6874R
I'm running my stock Audiophile HU and seems like most of the threads I am reading say to use something with at least 90 dB at 1 watt
The Kenwoods only have 87 and the Pioneer are 90.
Any opinion's on these two..
Well I ended up purchasing them lastnight... Ended up going with the Kenwood KFC-C6893PS. Got them for $41 per on Amazon. Should be here Tuesday and the Metra's should be here Wed.
Thanks for your help guys.
