removable subs and tweeter project
Old Mar 6, 2011 | 09:37 PM
shdow8948's Avatar
Before all of you downers say anything just know that i am stubborn.
I thought of the idea that maybe i could build a custom box setup for some subs and tweets and slide that inside a toolbox that is built to go in the bed of the truck. I would prob use 1x2 boards to build the box. the dimensions of the box are:
Length 69.75 inches
Width 20 inches
Height 13.188 inches
I am just curious what size subs and tweets i should get and how challenging the steps would be to have a hole drilled out from behind the back seat of the cab and through the front wall of the bed. i also want to know if there is such a thing as a "connector" or "plug" that could be used to unplug the system when not wanted or needed and be able to pull the toolbox completely out of the bed. I am aware that i will have to find a way to seal the hole in the cab if i do not want water coming in. any help appreciated. will post pics of the box. the truck is a 2002 xlt supercrew 4.6 2wd.
Old Mar 6, 2011 | 09:40 PM
shdow8948's Avatar
http://www.4truck-accessories.com/DE...arch_Year=2002
Old Mar 6, 2011 | 10:13 PM
go through the vent on the back of the cab.
depending on how many wires are going into the box you could get a male/female 4way trailer plug, that would have a water resistant cover for the cab side when not in use
Old Mar 6, 2011 | 10:18 PM
shdow8948's Avatar
how good of an amp could i stash in the compartment behind the seat?
Old Mar 6, 2011 | 11:24 PM
depends on the size of the amp.
btw what year truck do you have? cab configuration?
Old Mar 7, 2011 | 08:24 PM
shdow8948's Avatar
2002 xlt supercrew cab 5.5ft bed
