Qlogic & JL Audio Advice
Just got my Qlogic Single 10" box. I was wondering if I could manage to squeeze a JL Audio 10" W3 in there? I have a JL Audio 250/1V2 amp that I would power the sub with. The amp reads 4ohm, does this mean I would need to buy a 10" 4ohm Sub? What do guys think of the set up? Will it work,sound good? Any advice? O ya 2006 SuperCrew FX4.
THANKS IN ADVANCE
THANKS IN ADVANCE
Should sound fine. Are you sure the w3 will fit in the shallow q-logic box?
Sub resistance doesn't really matter with that amp, it has the same output from 1.5-4 ohms, so you're fine with either.
YES IT WILL FIT. How do I know this? Well its what I have now. When I first purchased this box the only sub at the time that would fit was an Infinity and that went bad on me. According to the JL specs it suppose to be off in depth by..... Well I forgot how much in depth but I bought it from Crutchfield, installed it and love it. I do have a rubber ring around the top of the sub just b/c i think it was of by a quater of an inch, couldn't be much happier and will never purchase Infinity again for a sub.
pmason,
Thanks for the help. What do you mean a "rubber ring around the top of the sub?" Is this something I would have to buy in addition to the sub itself? Also how any watts you pushing the sub with? I was hoping on using a JL 250/1 amp.
If I'm not mistaken it comes with the sub. Its this and round and it goes between the top of the sub (round part) and the box to give lift it up some. The sub is 500W RMS but my amp puts out 400W RMS
Sounds like mason is describing the gasket that comes with the woofer.
Be very careful relying on a spacer in a downfire box. You need to have room for the outward movement of the subwoofer (both cone and surround).
Also, I just saw that the W3V3 comes in an 8 ohm version, you'll want to stay in the 2 or 4 ohm models for your amp. The Slash 250 will push the W3, and you'll have the ability to sell it and move up to the slash 500 if you decide to later on.
If your not stuck on JL, an Image Dynamics IDQ 10 V.3 would work well in that qlogic box in that price range.
