intalling a sub using stock radio
id like to install a sub and amp into my truck using my stock radio. i have everything i need i believe. ive heard i should tap into the rear speakers and splice in a line-out converter, which i have. is that right? also a friend said in order to power the amp i should run a wire into my fuse box and shove one end of the wire into the spot where the fuse for the radio would be, leaving the fuse in there as well. that work? will that do anything to my radio? thanks.
Also, if you run off of the rear speaker and your fade is heavy to one side, you'll hear that in your sub. Another thing with doing that will be that your sub won't receive just the bass line but you'll get the mids that your 6"x8" gets too so what would be a sub is now just functioning as a large, out of door, door speaker.
You can run your line out from your stock radio to the amp and purchase an adapter for a sub so that you can connect to the line out.
They're around 25-30$.
Find your nearest speaker shop and see if they can order you one, nearly all knowledgeable shops will either have them in stock or be able to get them within a day.
I almost went that route, I'm really happy i got a head unit and did it properly. It sounds Awesome! You can pick up a Clarion double din touch screen unit for like $300. Wait, Save the money and do it right the first time.
i also done the adapter spliced into the rear speakers and it sounded great to me, until i put my new jvc hu in a couple weeks ago and hooked it all up and now i realize that before, it sounded awful.
I can appreciate what you guys are saying about how much better the sound is with an aftermarket HU....but I wonder how it would sound with a good summing device like the 3SIXTY or the Maxxsonics MX-1 and others that are out there instead of a cheap converter.
I am running a 3sixty.1 to supply signal to my amps. It sounds awesome and is much better than factory, but I replaced all my door speakers as well. I can't really see using a full on sound processor for just a sub though. If I was gonna go through the trouble I would go ahead and swap the door speakers too.
