best sub under $600?
Old Feb 12, 2010 | 07:46 PM
heckvr4's Avatar
what the best subwoofer(s)i can get for under 600bucks?? i am planing on building a box in the center console...
i was gonna go with a 13.5 jl audio w7...
rite now i have a 13tw5 with a jl 500/1 and it sounds great! i just need more bass...
if you name a sub , please tell me were to buy it...
any input welcome
Old Feb 12, 2010 | 07:51 PM
CedartownDawg's Avatar
18" Fi BTL fully loaded.
And you can buy at http://ficaraudio.com
Old Feb 12, 2010 | 08:04 PM
Ray21's Avatar
Best sub for? Getting loud, sounding good or a mix of both?
Old Feb 12, 2010 | 08:05 PM
heckvr4's Avatar
you think i can make it fit inthe center console ? i have a 05 screw fx4
Old Feb 12, 2010 | 08:10 PM
heckvr4's Avatar
yeah maybe a mix of both... i listen to all kinds of music ...
Old Feb 12, 2010 | 10:05 PM
ryjay7887's Avatar
i dont know if you can make that fit...unless you want to have your elbow to be in the cone. I know in my 06 f150 scab, the distance between the two front seats with console out is a very very tight 15 inches. the reason being is...there is some sort of device on the edge of both seats facing the center of the cab. I believe it has something to do with the seats sensors or seatbelts...i don't know exactly. but I do know that they are hard and dont really budge. it it wasn't for those, you could probally squeeze in a 16in wide box between the seats. I have seen a few people squeeze in the 15in wide box and put in a 15in L7 facing the front of the cab...in my opinion...thats a pretty awsome setup because with that setup..you can make the box as high and as long as you want....port that sucker and tune to 33hrtz and you will have a LOUD system.
P.S.- i wish we could put in a pair of 18" Fi BTL's in our trucks reasonably. I just need to use my back seat so i think its a lost cause for my application.
Old Feb 12, 2010 | 10:32 PM
If you put the speaker actually in the back, facing the rear and put your port out the front, you'd be able to maybe do it.
You asked for the best sub under 600, I gave you the best all around for the money.
They offer 12s and 15s too so look into those.
I've got an older Dodge Scab that I'm going to put a set of Fis in there, two 18s in 15 cubes. hehe
Old Feb 12, 2010 | 11:32 PM
heckvr4's Avatar
thanks man, i def want that 18" fi fully loaded, i have found nothing but good reviews on it...
good luck with those 2 18's...
also , how much air space will the 18" need?? i want it ported... andhow do you 'tune' a box???
building the box should be very easy since im a carpenter... i just dont know how big of a box i need.
any help its appreciated
Old Feb 12, 2010 | 11:39 PM
Last I remember, one of their 18s require right at seven and a half cubes and tuning is mostly dependent on the size of your cut out.
I've got a calculator somewhere.
Hang on a tick
Old Feb 12, 2010 | 11:53 PM
http://www.the12volt.com/caraudio/boxcalcs.asp
There it is.
It can do cubes, for different style boxes, and porting.
Old Feb 13, 2010 | 12:09 AM
heckvr4's Avatar
There it is.
thanks a lot , that really helps !
looks like ima need a big box ....lol
ill play around with the tape measure tomorow and see if i can make that 18" fit in the center console... if not , ill just get a 15"...
Old Feb 13, 2010 | 12:12 AM
Sundevil2188's Avatar
Old Feb 13, 2010 | 09:16 AM
ryjay7887's Avatar
haha nooo way am i cutting out the back wall of the cab. mabye if I was driving a 90's model f150 but not this one...I need to keep somewhat of a good resale/ trade-in value on it..
Old Feb 13, 2010 | 01:08 PM
heckvr4's Avatar
OK , so yeah theres not enough room for a 18" inthe center console... uhmmm...
i got 3 cubic feet to play with... should i go with a 12" or 15"fi btl...
i have a jl 1000/1 if it makes any difference
Old Feb 13, 2010 | 03:01 PM
firecop418's Avatar
intrested in selling the 13 tw5?
