04-08 BM box thread
I will be building my own box for the BMs using an upfiring design.
Also, you guys are worrying too much about getting the exact amount of power. As long as your amp does 300+ per sub you should be fine, these subs are efficient. If you amp does more than the BM's rated then that is also fine, turn the gains down properly and the amp wont have to work so hard which reduces heat and reduces possible distortion. My 2 BMs will be seeing a combined 1200 RMS from my Cadence iA7.
Oh also, the BM has no pole vent. Nick stated that you could literally put the back of the sub up against a wall (or 1/8" away so it doesn't vibrate).
here is one. I dont know what the baffle to floor clearence is.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
damn i may try this box seeing i am completely lazy and I guess my 750/1 will work then
Of course the 750/1 amp will work. That is one thing about jl, their amps are worth the money and are powerfull. I would bet that a 500/1 would work for those speakers as well.
I just e mailed him so i wll find out...I know the sub has 0.5512 inches of excursion..now i just gotta see how tall it is from the top of the box..i think i will be okay
I made a thread showing my sub box plans for a 13TW5 box I built. Maybe it'll help some:
https://www.f150online.com/forums/sp...supercrew.html
Don't forget about the height of the sub above the enclosure. I would venture to say that you need about 1 1/4" below the box to clear the sub during full excursion.
so 6mm for the part that hangs over the top and 14 mm of excursion gives you 20 mm at that it is 0.78 inches even at 25 mm of total including max excursion your still underneath 1 inch of space needed. I am sure (and hoping) it will be atleast an inch of space.....I think that makes sense? I'm probably wrong but that's why we have people here that know more than me that can chime in.
here we go
Ahhhh...... that's what I was looking for. According to that drawing you are correct.
If I didn't have a 13TW5 I would snag a couple of these subs and put them in my truck. I bet they'll be incredible low end drivers.
