what amp?
Old Jan 11, 2010 | 11:34 PM
Jonwasx's Avatar
Question what amp?
what amp should I get for my 2 4 ohm Kicker C12a subs?
Old Jan 12, 2010 | 12:38 AM
Sundevil2188's Avatar
got any idea what the RMS wattage is? I cant find specs on a quick google search.
Old Jan 12, 2010 | 01:28 AM
Jonwasx's Avatar
All i know is the max wattage is 400
Old Jan 12, 2010 | 01:30 AM
Jonwasx's Avatar
Would the MRP-M350 work?
Old Jan 12, 2010 | 09:54 AM
PorkCereal's Avatar
If max is 400 then rms is probably around 200ish. So an amp in the 4-600w range would work well. If probably settle in the range of 5-600 so your amp has extra power so your not jacking gains.
Old Jan 12, 2010 | 11:42 AM
Jonwasx's Avatar
Could I use the Pioneer GM-D7400M and parallel wire the two subs?
Old Jan 12, 2010 | 01:55 PM
PorkCereal's Avatar
From a quick google that amp shows 400w x1 channel at 2 ohms
http://mobile.jlaudio.com/support_pages.php?page_id=145
For wireing diagram. Dunno if they are single or duals so i dont know if u can get them down to 2 ohms. But it should push them ok if you have that amp laying around and ohms work
Old Jan 12, 2010 | 03:03 PM
phattacorider's Avatar
MRP-M500. Plenty of power for really cheap. About 500Wrms @ 2ohms @ 14.4V, so you'll be right around the 400W range or so @ 12V, safe for your subs and getting great voume.
Old Jan 12, 2010 | 06:48 PM
Jonwasx's Avatar
I think i'm gonna go with the Pioneer GM-D7400M and parallel wire them since my subs are single coils at 4 ohms
Old Jan 12, 2010 | 07:00 PM
You'd have to parallel your subs with any mono channel amplifier to draw better current.
