Need Advice on a SIMPLE System
Ok guys, let me start by saying that if there is one area that I know nothing about it is car audio. That being said, I have a 2005 SuperCab I am looking at doing a few upgrades in.
I figured a good set of door speakers front and rear and a single 10" sub under the rear seat. Just something that will hit a little more than stock. I dont want anything that will rattle the truck apart or cause me to have to pull all the carpet up and Dynamat everything. I also am going to add a iPod direct hookup.
So there is the plan. Lay it on me. Thanks in advance!
Well how much are you willing to spend. You can spend a little or a lot and that determines what you can do.
Id look into some sort of 5 channel amp, alpine type S in the doors ive been told are decent. Your going to have to set aside $$ for install or wiring + sub box. There are lots of posts around about boxes for your truck.
if i were you i would go with some polk audio door speakers. And as far as sub and amp i would definitely go with a kenwood class D amp and for subs i would probably put maybe 2 memphis audio 10" subs under your back seats. Or 1 12" just for the little boom that sill sounds good
x2, unless its old school. Their older amps were pretty legit, never stuff is typical trash.
why you hatin on kenwood every piece of kenwood equipment i have had has done its job without messing up or anything, i was pushing 2 memphis 10s and 2 audibahn 12s off a 1000w class d kenwood amp. there is nothing wrong with them an there not trash
BTW, that particular model you've posted is actually a 500 watt amp, rated 1000w peak/burst. And 95% of mono subwoofer amps built today are class D.
I got a kenwood Exelon for my W5v13 and it was a waste of money. Some cheap speakers you can put in the truck are infinity reference speakers. There cheap and sound better then stock. Or if you wanna spend a little more money you can get some Alpines.
