kenwood amp help
Old Nov 12, 2009 | 11:01 PM
sloenuf's Avatar
kenwood amp help
anyone know the rms rating on a kenwood kac-829 600 watt 2 channel amp? looked everywhere cant find it. any help would be great. thanks in advance
Old Nov 12, 2009 | 11:57 PM
wmitch927's Avatar
Google is your friend...
http://www.crutchfield.com/S-XcGa1Of...d-KAC-829.html
Old Nov 13, 2009 | 12:58 AM
sloenuf's Avatar
been there. dont see anything about the rms?
Old Nov 13, 2009 | 12:17 PM
wmitch927's Avatar
I'm fairly certain this is what you're looking for:
300 watts x 1 in bridged mode
150 watts x 2 at 2 ohms
In other words, if you bridge it to one channel for a sub, 300 watts rms.
If you power speakers that are rated at 2 ohms, 150 watts rms.
I think that's correct... Maybe someone else will chime in.
Old Nov 27, 2009 | 12:41 AM
sloenuf's Avatar
with the amp bridged and at 300rms and 600w peak. would it be better to run a 2ohm or 4 ohm sub?
Old Dec 2, 2009 | 12:35 AM
sloenuf's Avatar
any input? i believe i read somewhere that if you run 2 subs its 100rms at 4 ohm to each speaker. so if i bridge it i know its 300rms then to one sub. but is that 300rms at 2ohm or 4ohm? trying to figure it out before i make my speaker purchase
Old Dec 2, 2009 | 02:21 AM
Sundevil2188's Avatar
The amp, bridged, is 300 watts rms at 2 ohms.
Old Dec 2, 2009 | 10:42 PM
sloenuf's Avatar
i finally got a reply back from kenwood and a link to the book for the amp. its 150w rms x 2 at 2ohms, 100w rms x2 at 4ohms and 300rms x1 at 4ohms
Old Dec 3, 2009 | 10:33 AM
That doesnt make any sense.
Old Dec 3, 2009 | 02:03 PM
sloenuf's Avatar
email they sent
Thank you for contacting Kenwood USA Corporation. As an authorized agent for Kenwood, we are responding to your recent email inquiry.
When bridged the amplifier is not capable of supporting a 2 ohm load, only 4 ohms.
Old Dec 3, 2009 | 02:06 PM
sloenuf's Avatar
look under the specs. for the rated power output for 4ohm
http://www.kenwoodusa.com/UserFiles/...als/KAC829.pdf
Old Dec 3, 2009 | 11:40 PM
Thats wierd...ive never seen an amp before that will run okay at 2 ohms in normal but not when bridged.
