Replacement sub for 1997 Expedition
Old Oct 22, 2009 | 01:09 PM
97expedition's Avatar
Cool Replacement sub for 1997 Expedition
Hi Guys,
I need your help to figure which subwoofer I can use to replace the OEM one.
The OEM one does not work anymore.
I have a 1997 expedition Eddie Bauer with the Mach sound system.
Front and rear speakers are still working great but it is not the case for the sub enclosed near the 3rd seat.
I want the replacement sub to be located in the exact same place as the OEM one.
Any idea ???
Thanks for your help :-)
Old Oct 27, 2009 | 11:14 AM
F150man21's Avatar
here ya go
http://www.sonicelectronix.com/item_...C+Loaded-.html
Old Oct 31, 2009 | 01:14 AM
broadbent23's Avatar
well the speaker is a 8" speaker and has a 4 ohm impedence and 150 rms. so if you want it in the same spot in the original box then you would need to get an 8" sub with similar power and impedence ratings. if you want a bigger speaker you have to get a bigger enclosure
