Loud pop with stock sub and aftermarket HU
Old Oct 17, 2009 | 11:32 PM
ktmrdr85's Avatar
So, I got all of the other stuff figured out with wiring the new HU to the factory amp and sub. But I figured I'd start a new thread for a new set of problems.
The problem that I am having is that when I start the truck, the sub makes a loud pop.
I was told in my previous thread that I needed to install a resistor, so I went to radiocrack and got an 8 ohm resistor and installed it a while ago, and after a little driving around, the sub still pops.
When I wired the thing for power, there wad two wires and I only used one and the sub works now (which was my other problem).
Old Oct 17, 2009 | 11:59 PM
pmason718's Avatar
I did the radio shack resistor for a friend of mine but if I knew better back then I would have just bought this. Maybe give this a try
http://www.sminntech.com/ampinterface.html
Let me know if this helps
Old Oct 18, 2009 | 01:09 AM
ktmrdr85's Avatar
I might try that, is there any other options for my problem?
Old Oct 18, 2009 | 11:15 AM
ibcop's Avatar
I don't know what I used will help, but I had the same problem when I added a Pioneer DVD head unit. I was told to use a specific voltage regulator from Radio Shack. The item number is 276-1770.
Here is a pic:
I hope this helps you.
Old Oct 18, 2009 | 11:29 AM
JJDH's Avatar
Here is a pic:
that is what you need.. i used that at one point
Old Oct 18, 2009 | 06:36 PM
ktmrdr85's Avatar
K guys.
I might try that.
It seems a little more attainable then the other thing mentioned.
