Memphis vs JL Audio
Old Sep 29, 2009 | 11:43 PM
mexican_951's Avatar
Memphis vs JL Audio
So which ones better???
The Memphis PR series or the JL Audio W series?
Old Sep 30, 2009 | 01:48 AM
sanndnsurf's Avatar
Ive heard really good things about JL's
Old Sep 30, 2009 | 01:51 AM
abervintageman4's Avatar
okay well all of jls subs are technically w series, but prs are not horrible subwoofers by any means, it all depends on the install
Old Sep 30, 2009 | 02:40 AM
terrill's Avatar
Memphis MCP class or Memphis C3 are better.
Old Sep 30, 2009 | 09:44 PM
justinj702's Avatar
i like jl more
Old Sep 30, 2009 | 09:57 PM
4X4AUTIGER's Avatar
Neither
Old Sep 30, 2009 | 10:46 PM
mSaLL150's Avatar
I would look into the JL w0v2. JL Audio did some nice R&D on these new drivers and they will fit under the seat and give you a decently flat response in a smallish sealed enclosure.
Old Oct 2, 2009 | 12:27 AM
turnin24s's Avatar
jl audio all the way
Old Oct 2, 2009 | 01:32 AM
Saint83's Avatar
I have been looking at these. there is also a SVC of them.
http://www.crutchfield.com/p_107MM12...0D.html?tp=111
Old Oct 2, 2009 | 04:25 AM
weazel's Avatar
Registered User
Is this a Real JL recommendation From you!! lol
Old Oct 2, 2009 | 04:37 AM
hlbbig69's Avatar
my take on the jl's had them in an f250 and now a f150. Both were screws the f150 just kicks a$$ tight and low bass in a sealed box. I used the jl 10wiv2 in both truck and the type of box does make a big difference for these subs. the 10w1v2 requires .625 cubic air space. My f250 had .9 cubic vol inside the box but, the box was behind the seat it was tall, wide and very shallow we had to notch the inside of the back of the box so that the magnet would have enough clearence. Unlike the f150 I used subthump box and they say there box volume .64 It hits hard for a sealed box.I can play tech master P.E.B.in the f150 no way in the f250 would flop to me that says alot about the combo subthump and jl. One downside to the subthump box you have to replace the speake terminals to the screw in type. Otherwise you will blow out the ones that they use i wedged them in with a rubber mallet and they still blew out.
Mark
Old Oct 2, 2009 | 04:01 PM
alexarizpe's Avatar
i cant tell you on the pr series cause i havnt heard them or installed them but i got two 10" memphis m3's and it sounds alot louder cleaner than when i had the jl w3's in there (same amp/box). dont get me wrong i love jl audio i use to compete back in my highschool years just spl though not sq i had 3 15" w3's. and im still thinking about switching to the jl audio thin line subs. i hear those sound killer. well good luck
Old Oct 2, 2009 | 06:53 PM
fritz4077's Avatar
i got two Memphis M3 15's hooked up with a Memphis 5 channel amp pushing about 1500 rms at 1 ohm and they hit real hard and amazing sound quality.
Old Oct 9, 2009 | 12:13 PM
SVTVERNMAN's Avatar
I run a JL 900/5. No problems at all.
