need help with a port
Old Sep 20, 2009 | 09:24 PM
gcw's Avatar
gcw
Ive been thinking about getting some pvc to port my box with. I went to 12v and used the calculator and it said for a 2" port it would be a 1 1/2 long? Maybe im doing something wrong idk any help would be gratefully appreciated.
my box has 2.5 cu/ft
its sizes are (trapezoid)
48" long
7" wide at bottom
5" wide at top
18" tall
Old Sep 20, 2009 | 09:34 PM
gcw's Avatar
gcw
does this sound about right?
Old Sep 20, 2009 | 10:28 PM
Impact9's Avatar
I'd say that short port is way way off. I'm having a ported box designed by a pro and the port going to be nearly 26" long and around 6" square. But that's just a guess from the rough design pics he sent me. You might email dylan AT fishercustoms.com
GCW's screenshot could be right but I'm no expert. That's why I emailed Dylan =).
Oh..He does this for a living so he may want a few dollars to figure this out for you.
Old Sep 21, 2009 | 09:12 AM
bigchief2472000's Avatar
a smaller port opening needs less port length, but you have more port noise with a small opening.
Old Sep 21, 2009 | 11:57 AM
gcw's Avatar
gcw
ok so i just plugged in a (1) 4" pipe it says 10" long? im want to put it on one side of the box instead of the the front will that matter?
Old Sep 21, 2009 | 07:49 PM
a port on the side should be fine or you could do a slot port starting at the bottom front and 90 up the back wall to get the rest of your length. (1) 4" port 9.6" long = 33 HZ according to winisd, seems to be the same as what you came up with.
Old Sep 29, 2009 | 09:31 AM
OMF350's Avatar
RE Audio's website has the best port calculator Ive seen online.
reaudio.com
