porting a under the seat box????
Old Sep 3, 2009 | 05:44 PM
FX4_2003's Avatar
Ok Pioneer sub says I can port a 1.0 cubic foot box so I am going to port it out the front .. with PVC..
Sub is firing down , Port out the front 3 inch dia.. 6inches long ... (PVC ) I havent drilled the port yet ..
Box Dia.. 25 wide x 13 deep by 9 front height and 6 back height , Seat lifted ..
Using the port calc , tuning will be at about 47 hz..
Or should I just leave it Sealed ????
Old Sep 3, 2009 | 05:56 PM
4X4AUTIGER's Avatar
build a bigger box or leave it sealed.
47Hz is too high for a daily setup
Old Sep 3, 2009 | 06:41 PM
FX4_2003's Avatar
Ok will do .. I thought 47hz was a little high ... So sealed it stays for now .. starting a new build next week .. I got to make a nicer looking box ..4X4AUTIGER
thanks for the help
Old Sep 3, 2009 | 06:51 PM
CountryPunk's Avatar
Agreed.
Old Sep 4, 2009 | 11:15 AM
FX4_2003's Avatar
Mod the old box
Well since I am building a better looking box I thought why not play with some ports and the calc. just to see what would happen... Ok First test I used the manufact. Specs for a 1.0 cubic foot box at 3 inches round PVC X 6 inches long.. Not to bad but only 48 hz according to the port calc.. Ok so then I tried 6.5 inches longand got about 46.6 hz and it sounded a little better..So then I tried 7 inches long 45.5hz and it sounded great...but since this is a test I went extreme and tried 8 inches and about 43hz and it sounded real real good ,, I went to 9 inches and got about 41 hz and the sub sounded a little fuzzy .. So I liqued nailed the 8 inch into the box and it is drying as I type... So at 43 hz this little pioneer pounds its butt off... Now to make it somewhat not so ugly I angled the port and crafted the liqued nails smooth all aroung the port and it will be painted black in about a day once the liqued nails dries ... And Yep I am going to take pictures ..
Old Sep 4, 2009 | 07:47 PM
FX4_2003's Avatar
You want to know why people buy prefab boxes ????? HUH HUH !!! because they are a pain in the big ole freakin A double S ..... to build.. Well as luck would have it I installed the enclosure terminal cup and oh crap no solder .. what was I thinking so I guess I will work on it somemore tommorrow... Oh by the way When I took the sub out of the box it had this kind of electrical smell but its not blown it just smelled funny is that normal??
Old Sep 4, 2009 | 08:57 PM
Impact9's Avatar
ahh don't be a wuss they aren't that hard if you got the tools.
Course I've only built one ported box and I'm trying to find plans to build a underseat ported box for my 10" sub 1.5@36hz
Old Sep 4, 2009 | 11:24 PM
FX4_2003's Avatar
Ok here are a few bad shots , I still have some trimming and sanding to do .. Just waiting on the silicone and liqued nails to dry.
Old Sep 4, 2009 | 11:26 PM
FX4_2003's Avatar
Oh and ignore the long peice of cheap wire , I used it to hang the box up while I was painting the rubberized spray... I have 10 guage monster cable wire for the sub...
Ok the project for tommorrow is dowel rod for the feet of the box, then finish trimming and sanding , re prime the box , then apply a few coats of black liner paint ... This box is getting real heavy , but it is sealed tighter than an ants butt cheeks..
Old Sep 4, 2009 | 11:34 PM
abervintageman4's Avatar
sweet, be sure to post some videos
Old Sep 5, 2009 | 08:10 AM
FX4_2003's Avatar
Man Liqued Nails takes forever to dry... Darn Mississippi humidity... And also I am out to wally world today to buy a palm sander.. I have always wanted one but now that I actually need one I figured what the heck might as well .. Just got to get out of here before the wife wakes up..Oh yeah got to get solder as well ...I will get a few more photos today ...
Old Sep 5, 2009 | 10:26 AM
Impact9's Avatar
Just an observation but that box looks like it's made from particle board. Is it?
Old Sep 5, 2009 | 01:47 PM
FX4_2003's Avatar
yep particle bord 3/4.. Ok here is one video installed and some pics
Pics first
and the video 1
http://www.youtube.com/watch?v=yCh1z-klsfQ
Old Sep 5, 2009 | 01:53 PM
FX4_2003's Avatar
Ok the bass is alot smoother , sounds alot louder .. and the amp runs alot cooler ... I think its a plus///// So 1.0 cubic foot ported with a 3 inch thick wall pvc at 7 inches long ... WOW..
http://www.youtube.com/watch?v=Wx5P3i8cnTc
ANOTHER VIDEO ><><><><><><><><><><
Old Sep 5, 2009 | 04:23 PM
Impact9's Avatar
You may consider rebuilding it later down the road using MDF. Particle board is not dense enough to allow the sub to perform well. It's like using a balloon as a box. Yes it does work but you loosing performance.
Paint the inside of the box to protect it from moisture other wise it will swell up and be worthless.
Loose the weatherstrip it's not going to stay put. If your sub is leaking around the basket you can take some silicone sealant and put bead around the basket. You can also cut a new ring or order one online if you hole suffers from jigsawastraus.
