Mounting the sub under crew backseat
Old Jul 20, 2009 | 05:14 PM
FX4_2003's Avatar
Sit back because I gave up on mounting my sony sub to the backwall of my crew cab... I hate my Sony Sub I wish I would have just bought a Kicker Shallow already in the box but my coustic amp would probably blow it too.. So now my sub pops at loud low deep bass... all from a coustic 241se bridged.. So I got to use what I have until I can get more money.. Got bills to pay .. So why does my Sub Pop .. I have had everything set perfect ...
Well anyway I have a job tonight so I will be working on the underseat mounting tommorrow when I wake up ..
Maybe my cheap coustic 241se.. with 240watts rms X 1 @ 4 OHMS IS MORE THAN this 450 rms ----1100 max watt sub can handle..
ALL HAIL THE COUSTIC AMP
Old Jul 20, 2009 | 06:14 PM
FX4_2003's Avatar
Thought about this with dual voice coils ...... I can run my coustic amp at 80 x 80 then maybe this is the an I can use a smaller box..Plus its shallow mount ..
http://www.overstock.com/cart?addqty...2&BUY.y=23swer
Old Jul 20, 2009 | 07:01 PM
FX4_2003's Avatar
I am going crazy ... I think perhaps my coustic amp is throwing some strong DC Current into my sub... So I have no choice but to buy another sub amp.... I think I may just go out and buy me a new Ipod and some headphones .. Cause DEEEEAAAANNG this shiznick
quahomma I have got myself into has cost me a bungie load of money >>>>> I would really like to get my stereo sounding good before I get to Old to listen to it..
Old Jul 20, 2009 | 08:41 PM
FX4_2003's Avatar
A sickening 6 min display of my wasted 60.00 dollars at walmart and a very crappy Sony Subwoofer that lasted 2 months.. This is being driven by 240 watts from a 241se coustic amp
http://www.youtube.com/watch?v=VGpXT9hBp70
My Sony Sub has a Bad Farting Problem..
I did notice that the sub fit in the cut out sort of tight ,, maybe the cage is wedged in to tight causing the voice coil to be misaligned with the magnet, as I have not smelled any burning at all.. And it only started this when i put it in the new enclosure...
Old Jul 20, 2009 | 08:49 PM
JJDH's Avatar
just so u kno the current to the sub is ac.... not that that helps ur situation
Old Jul 20, 2009 | 09:05 PM
FX4_2003's Avatar
Yep its supposed to be AC ... But this coustic amp has been blowing alot of subs lately...
I am thinking of going with the shallow mount Lanzar it dual voice coil and I wont be bridgeing my amp.. so by doing this I am only putting 60 watts to each 4 ohm voicecoil.. Maybe I could make the Lanzar Vector 10 in sub last a little while .. When I had my Dual Subs running both of them in stereo mode , No Problem but when I got the FX4 truck I only put one sub and the coustic amp bridged actually blew the voice coil all the way out of the sub...If there is nothing wrong with my coustic amp ,, I will never hate on them because this amp has blown some of the subs rated 4 times its power output..
Old Jul 21, 2009 | 08:31 AM
FX4_2003's Avatar
Ok its 7:30 am Tuesday morning .. I am in the process of removing the back longer seat again and also I ampulling the sub out of the box to look for anything causing the popping sound.. I am also going to go around the box once again to make sure that there are no leaks ..Found an easy way to do this put a flashlight in the sub box and close off the front sub hole .. take it in a dark room and waaalaaa there you go... If we get it all back together and its a no go , then we start ordering stuff... Anyway I am off to the hardware store in about an hour but first it's TIME
Old Jul 21, 2009 | 10:57 AM
ProblemHouston's Avatar
How big is the box?
Is it ported or sealed?
What are the subs rated RMS that you are blowing?
How are you tuning your amp?
What are you listening to when the popping occurs?
Old Jul 21, 2009 | 01:48 PM
FX4_2003's Avatar
New under the seat box built .. Found the problem Sub was slightly wedged tight in the enclosure .. no popping yet.. Sealed box 13deep x 25 wide x 9 front height and 5 back height .. Roughly 0.93 cu like the sub calls for .. Sealed box .. ( and I mean sealed with 3 tubes of liqued nails ) my sub is rated at 300 watts SONY RMS (LOL ) 1100 watts peak ( in it's dreams ) Amp is set to roughly 3 volts sens ( input ) which is what my Pioneer HU puts out .. The low pass filter is on , the crossover is set between 50hz and 80 hz .. Bass Boost all the way down.. My other amp is set similar but with crossover in flat position...
Head Unit crossover for Sub is set to 63hz + 1 , Bass on 0 Low Eq on 0 , Mid eq on4
high eq on 6... ( head unit cut offs set to 1khz mid , 10khz highs and 63hz lows... The sub sounds ok since I built my 3rd box ..I think it will be fine .. Just waiting for all the liqued nails to dry on the brackets
Old Jul 21, 2009 | 06:06 PM
Glad to hear you got it all ironed out. You will have to post pictures.
Old Jul 21, 2009 | 08:32 PM
FX4_2003's Avatar
The bass is still a little fuzzy sounding but I chalk that up to the amp... After reading the coustic manual on the 241se the distortion on this amp is not very good at louder volumes.. so time to search for a good mono amp with around 150 to 300 watts rms.. I will take fotos tomorrow morning..
Old Jul 21, 2009 | 11:11 PM
FX4_2003's Avatar
Here are a few photos of what i got done today still along way to go..
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.photobucket.com/flash/rss_slideshow.swf?rssFeed=http%3A%2F%2Ffeed945.pho tobucket.com%2Falbums%2Fad298%2Fbevy12345%2Ffeed.r ss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s945.photobucket.com/albums/ad298/bevy12345/" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>
Old Jul 21, 2009 | 11:12 PM
FX4_2003's Avatar
Here is what I got done today.. Ignore the date on the picks I am to lazy to change it
http://s945.photobucket.com/albums/a...view=slideshow
Just click the link I cant get spit to load on this forum ..
Old Jul 22, 2009 | 09:00 AM
FX4_2003's Avatar
This is crazy watch the store window
http://www.youtube.com/watch?v=cedfX-gzHuM&feature=fvw
Old Jul 22, 2009 | 09:19 AM
FX4_2003's Avatar
Talk about excursion
http://www.youtube.com/watch?v=npdXc...eature=related
