Front Door Panel Removal
Hello all,
There is a lot of useful information through out this board!
I just bought some new Panasonic TS-A6865 3-way speakers for my truck along with a DEH-P7200 CD/Receiver. (Never did like the factory "prem." system.) I have installed the revceiver, but can't seem to figure out how to remove the front door panels to put the speakers in. I cannot locate any screws in the panel, and I am afraid of cracking the panel if I just pull on it.
Does anybody have any info. on how to remove the panels on the front doors of a '97 F-150.
Thanks for all of your help.
'97 F150 SuperCab XLT StyleSide; 4x4; Dk. Red
Felix,
Here you go, this should help you out. After you install them come back on here and tell how they sound. I am looking into a set of these and I want to know how they sound in a truck.
http://www.ford-trucks.com/articles/speaker_inst.html
00 Black Lightning
No mods yet
00 Honda Civic
01 Pontiac Grand AM GT
00 Black Lightning
No mods yet
00 Honda Civic
Heya Snake,
I appreciate the response. I have seen this article, but I think the layout of the door panel in the '97 is different. I could be wrong.
The article points out two screws that I can't seem to locate on my doors. Is there a piece of trim that needs to be popped off in order to get to the screws?
Again, I appreciate your help!
There is a screw cover near the door handle and you also have to remove the door handle.. 10mm i think. good luck
KV
'97 F150 SuperCab 4.6L Auto 2WD
Burgandy
Nerf Bars
Cat Back exhaust with Magnaflo dual 3" pipes
and tipsout the back.
SuperChip
K&N Drop-In Filter
Bosch Platinum +4 spark plugs
Manufacturer Supplied flaw for Door Crack
1/4 16.747 @81.73 (this will improve)
Track Time Pics
KV
Burgandy
Nerf Bars
SuperChip
K&N Drop-In Filter
Track Time Pics
I just had the same speakers installed in the front doors of my 97 reg cab and I can say it is a giant step up from the factory speakers.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks
