So 6.5's will fit in stock openings?
I have heard alot of you say 6.5 component speakers will fit in the stock openings, this requires no cutting or grinding right? What do you do with the left over space on the edges? Did you build a custom plate to house the 6.5? Thanks.
00 Black Lightning
No mods yet
00 Honda Civic
01 Pontiac Grand AM GT
00 Black Lightning
No mods yet
00 Honda Civic
In order to get the 6.5's to fit you have to either buy or make (which is better) a mounting plate. You can use the old 6x8 that your are replacing as a template to cut the mounting plate for and drill holes to put it on the door. I use plexiglass when I do it and I have had people tell me that they use wood, which I may try next time. But which ever you choose make sure it at least 1/4 in thick, or a little more. The thicker the mounting plate the easier time you will have installing the 6.5. It's kinda hard to explain everything, but once you work on it you relize the problems to work around and understand everything better.
But it can be, just patience and some brainpower.
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, pilot ground searchers, borla SS split rear exhaust, K&N genII, bosch +4 plugs, superchip, flexalite electric fan, v-tech oval side window covers, IAS shocks
premier 720, pioneer 6cd changer, 12 premier sub, premier componets, 2 soso amps
still to come: new spark plug wires, new rims and tires, maybe a supercharger eventually.
I've been thinking of switching to a round
speaker as well. Do round speakers actually sound better,or are there just more choices available? I am speaking
of coax speakers,not the single driver only
component style....any help is appreciated,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Euro style tail lights
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good]
Viper 500HF Security system.
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order Still want to lift it,YESSS!
Come see my new picturesat www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
I HAVE COMPONENTS SPEAKERS THEY ARE 6.5 BUT HAD TO CUT A HOLE IN THE LITTLE TRIANGLES THAT ARE ON THE CORNER OF THE DOORS ON THE 97 AND 98 F150 MODELS ITS A PERFECT PLACE FOR YOUR TWETTER IF ITS UNDER 2 INCHES.
I just took my factory rears out and replaced them with the 6 1/2" Infinity Kappa's from my other truck. I used the factory plastic speaker holder. I just went to the hardware store and bought some fiber washers and different screws with locking washers so I could use 2 of the existing holes. I bolted the speaker to it from the backside. There is a gap on one side, but my installer friends said it wouldn't make a difference unless I was putting components in.
Sounds great!
2001 SuperCrew, Gen. II
**Dealer installed propane conversion. Delivery: Oct. 21
*Silver* XLT 4x4, 5.4L: power driver's seat, captain's chairs, lim. slip, skids, tow pack, cage, moonroof.
Additions:
-16x8" Galaxy Centerlines with 265/75/16 Big O all terrain XT's,
-Waag wheel to wheel nerf bars (black with chrome steps)
-Trenz billet grill
-Sprayed black rubberized undercoating on axles, etc.
-Ford locking gas cap
-Gray Husky liners, front & rear
-Black/chrome pedals
-Pioneer stereo/cd controller, Pioneer 12-disc changer, 4-channel Profile amp in parrallel runs 6 1/2" Infinity Kappa's in rear & stocks in front (will replace with Orion components) & Bazooka subwoofer
On order: 47 piece carbon fiber dash kit, bug deflector, Gray spray-in bedliner, window tint.
Future: Ravin exhaust, Airforce 1 FIPK, graphics, cap & rear Altezza lights when they come out
Sounds great!
Additions:
-Trenz billet grill
I agree with 54regcab, if your not gonna install components in not worth it to make the plates for coax. Components make a huge difference in sound over a coax, where as round vs oval coax you won't notice much unless one speaker is much better quality then the other.
