component speakers installed
just got done with the install of my prs720, these sound awesome. if there are components that the mid sounds better, than they must be off the charts, these rock, clean clear,loud....
I agree, they sound incredible. I'm glad you decided to go with the MDF in the panels, looks good and I'm sure it sounds much better. I keep forgetting to upload my pics. Will do when I get home in the AM.
JJDH:
They look great. Are they 5.25 or 6.5?
There is a 5"x7"/6'x8" cut out in the panel already. SO, if you make a template to bit, you don't have to mod the door panel. In my case, the 6.5" mid was bigger then the opening, to the top and bottom had to be trimmed.
For you guys that are attaching it straight to the plastic door card using baffles, i suggest you get some deadener on the backside of that door card or else they will buzz with high power to those mids.
nice. always trying to p i s s in the rice crispies...lol all door holes are sealed. the door skin idea is more popular, i mulled it over, when u trim the door panel if it isnt sealed back to door skin, wouldnt the sound go up behind the panel? then if u only trim enough off panel to still touch door skin it seemed like a pita to put panel on without hitting or scraping the surround. like i mentioned before, if it dont work out, the option to change is always there. so far so good, forget the system...want to run em?
is this a spray or did u cut chunks?
The reason why I didnt mount mine to the door skin is because I had a hard enough time getting the panel back on without the speaker. Add another inch or two and it would be pure hell, all the while tearing my speaker up. I'm quite pleased with mine in the panel.
