ED 11ov.2 clearance
ED 11ov.2 clearance
Just saw that Elemental Designs is running a clearance on the 11ov.2 dual 4 ohm version.. Normally $185, going for $75.
Too bad they need a mounting depth of a little over 6 inches...
Looks like a good deal if you have a seat lift though.
http://www.edesignaudio.com/product_...roducts_id=830
Specs:
Qts: .33
Qes: .36
Qms: 3.7
Fs: 22.00Hz
Re: 7.4
Vas: 70L
Mms: 125.0g
Bl: 18.90T*m
SPL: 85dB
Sd: 350cm²
Xmax: 18.3mm
Voice Coil: 50.0mm
Magnet Width: 5.700"
Cutout Diameter: 9.125"
Mounting Depth: 6.125"
Weight: 20lb
Total Height: 6.500"
Displacement: .06 ft³
Outside Diameter: 10.250"
Sealed ( small ) 0.4ft³
Sealed ( ideal ) 0.5ft³
Sealed ( large ) 0.6ft³
Vented ( ideal ) 1.0ft³ Tuned to 30Hz
Vented ( DDLoud) 1.2ft³ Tuned to 35Hz
Specs:
Qts: .33
Qes: .36
Qms: 3.7
Fs: 22.00Hz
Re: 7.4
Vas: 70L
Mms: 125.0g
Bl: 18.90T*m
SPL: 85dB
Sd: 350cm²
Xmax: 18.3mm
Voice Coil: 50.0mm
Weight: 20lb
I believe you have 1 1/2 inches clearance with that box.
I will tell you for sure in a couple of months.
Here you go:
http://www.foxacoustics.com/ProductD...de=F150-210-04
Here you go:
