Which sub? Infinity or Memphis?
Old Apr 17, 2009 | 01:31 PM
Zaairman's Avatar
Arrow Which sub? Infinity or Memphis?
I'm debating which sub I want to put in my truck.... Currently, I have a Memphis Studio 12", SVC. I have a 12" Infinity 120.3DVC that could also go in there. Thoughts? The box is a 1.5ish sealed box. Power will be coming from an Infinity Reference 610a 456watt amp. I'm thinking about just throwing the Infinity in there for kicks and grins. How should I wire it up? This dual voice coil thing is new to me...
Old Apr 17, 2009 | 01:40 PM
LOHfootball53's Avatar
wire them both up and see which one you like better....one might be louder and the other might have more SQ
Old Apr 18, 2009 | 04:42 AM
MDK's Avatar
MDK
I've never heard Memphis but have always been told they're amazing but just by looking at what you got I would go with the DVC since it allows for more wiring options. Wiring option will depend on how many channels you amp is. Start here:
http://www.crutchfield.com/learn/lea...amp_guide.html
Old Apr 20, 2009 | 12:31 AM
Zaairman's Avatar
Amp is an Infinity 610a amp... Mono. 456 watts. How would I wire up the subs? Like I said, DVC is new to me...
EDIT: Amp is 456 watts at 4 ohms. 657 at 2 ohms. Is there any advantage to one way over the other??
Old Apr 20, 2009 | 01:14 AM
MDK's Avatar
MDK
I hope you read the link I provided cause it could've answered that question. First thing you need to figure out is what ohm rating is the DVC. It apears that this sub is 4-ohm out of the box from my research. Next is the RMS rating of the sub to see what amp you need, looks like it's 300watts RMS. I take this info along with the info you provided about the amp and the optimal setup is a basic one. DVC just allows more wiring options so it looks like you you'll want to still run the amp in 4ohm mode since 657 watts@2 ohms for a sub that has a mid power rating is not a good idea. Hope this helps!
Old Apr 20, 2009 | 10:58 AM
Zaairman's Avatar
I've seen that link before, thanks. Just wasn't sure if I wanted the 2ohm at the sub or the amp. Oh, and the subs are 300RMS, 1200 peak.
