will these subs in this box fit under my back seat
http://www.supercrewsound.com/commer...dId=7&catId=56
http://www.crutchfield.com/p_13610W3...h=jl+w3&tp=111
I have an 06 fx4 scab and I would need the optional extra mounting depth for them but other than that would they work?
Edit: Would one of these be a better option?
http://www.audioboxesonline.com/Ford...C04CS_p_7.html
.<---??? wtf?
.<---??? wtf?
box
.<---??? wtf?
.<---??? wtf?
thanks that looks like what I need. One more thing, I dont really want to spend a ton of money I'm just looking for some bass so would one ten inch do what I want because as much as I would like to be able to bump I am already getting a 6" lift and 35"s so I don't really have alot of money to spend.
well I have a friend with two kicker comp 12"s in his jeep and thats more than I need but since my truck has no subwoofer it just feels like somethings missing when I'm listening to any type of music. Basically I just want to be able to turn it up and feel it hit but not have my truck rattle apart
ok so how about this setup....the supercrewsound box for a single 10" sub, and the JL 10w3v3 Can I have some suggestions for a good amp to power that sub that is affordable?
Edit: Anybody use this head unit? http://www.crutchfield.com/p_130P310...B.html?tp=5684
hu
pioneer
i didnt really look at the hu he was showing, it just looked a bit entry level, thats why i would recommend premier, , i have never once had a problem in 18yrs with pioneer, not once. with what he wants to do pioneer would be fine, he wont need the highend , or anything .....nice truck bty doesnt that fuse have something to do with the line output voltage,if the amp needs more and hu isnt putting out it goes? anyhow, never seen one go.
the pico fuse is a major problem with pioneers. its easy to blow and once it does the ground is lifted and the HU grounds itself through the RCA's resulting in HORRIBLE alternatorwhine. its a well known issue in the car audio circle. its just best to avoid the problem and go with a kenwood, alpine, eclipse, or clarion.
I wanted to use the fox acoustics box and put two of them under my back seat, and that box has 6 1/8" mounting depth with the optional ring, but then the sub would hit the floor at full excursion. The top of the sub will actually sit about 5/8" above the plane of the bottom of the box, leaving you with only 3/8" of room for excursion. The JLw3V3 has 14mm of excursion, which equals .551" inches, which is more than 1/8" of an inch greater than the clearance you would have.
Looks like there is no way out of it without a seat lift or a very meticulously built box. However, only about a 1/2" seat lift would be required and then you could shim up the box...which is what I am thinking about doing
