Here we go center console sub enclosure build
Old Apr 27, 2009 | 09:45 AM
  #121
05_sprcrw's Avatar
Day: 15
Now that the paint has dried, I glued and screwed the plexiglass to the top of the box.
While that was drying I laid out the top console pieces and packed them with non hardening modeling clay to help reduce felt vibrations in the console. I used only about 10 lbs in the console, I will probably add more at a later date. I found that instead of working the modeling clay until it got soft that if you soak it in HOT tap water for about 30 min it will become a lot more workable and is a lot easier on the hands. I then packed the clay around the mounting base for the DIYMA to make a good seal, and help dampen the box from further vibrations.
Packing clay around the console:
  #122
05_sprcrw's Avatar
Once the glue was dry I started to assemble everything for the final time. I bolted it all back together added one more bracket to the rear of the box so I could bolt it down to the floor.
I dropped the DIYMA into its final resting place and tightened down the screws. I moved it out to the truck put it into place, soldered the connections together, and finally powered up the system………..
  #123
05_sprcrw's Avatar
And all I can say is this sub is by far the most translucent sub in existence! I am simply amazed at how well this thing blends and how accurate this sub is. It simply does not get better for a sq sub. (If you are local and want to hear it just let me know I will be more then happy to meet up with you)
And since I was bored and decided my D3 would need a good wallpaper to match up with the system I made it a new background:
Well that is all I have hopefully it inspired some of you to do something that may be outside your comfort level. I learned a lot through out the build of this and now am surrounded by complete musical bliss when I drive.
Final build specs are:
JL 500/1 v1 pushing a single DIYMA R12 in
a custom console enclosure with .5 ft^3
JL 300/4 v1 bridged pushing Diamond Audio Hex 6.0 speakers
Using the 5.0 crossovers with the silk tweets
KnuKoncpetz install accessories
Tech Flexed all wires
Pioneer Avic D3 dvd/navi hu
The big 4 re wire
Raamatt sound dampener.
Old Apr 27, 2009 | 10:07 AM
  #124
looks good! How much clearance do you have between the magnet and the pexi?
Old Apr 27, 2009 | 10:17 AM
  #125
05_sprcrw's Avatar
It approx 1" it looks really close though.
Old Apr 27, 2009 | 12:31 PM
  #126
bigdog87's Avatar
Looks AWESOME
Old Apr 27, 2009 | 01:59 PM
  #127
Jaderbutt's Avatar
WOW!!! What a great build! Thank you for taking the time to take pictures and post them on here!
Old Apr 27, 2009 | 02:03 PM
  #128
Steeda1996's Avatar
Looks good! I'll bet it sounds even better.
Old Apr 27, 2009 | 02:11 PM
  #129
05_sprcrw's Avatar
No prob and thank you
Thanks, and yes it does sound a lot better then the build looks.
Old Apr 27, 2009 | 02:16 PM
  #130
wick246's Avatar
Nice work! I was having a hard time picturing how it was all going to go together. Looks nice and out of the way. Glad it sounds great...
Old Apr 28, 2009 | 08:32 AM
  #131
dittothat's Avatar
Very nice work. Maybe you should go work for JL and get them back in the business of making center console boxes
Old Apr 28, 2009 | 08:46 AM
  #132
05_sprcrw's Avatar
That would be sweet but I don't think that I have the required skill set to pull that off :o Plus it was a huge under taking to figure this one out, but I think to do it again it would go a million times faster now that I know what little snags I will run in to.
I do thank you and everyone else for the compliments, I am just glad it sounds good. I was so worried that I was going to do all that work and it was not going to sound good
Old Apr 28, 2009 | 11:03 AM
  #133
Drkharbinger's Avatar
Friggin awesome
Old Apr 28, 2009 | 05:24 PM
  #134
05_sprcrw's Avatar
Thank you I am very happy with it
Old May 7, 2009 | 08:31 PM
  #135
jump n's Avatar
Very cool, 05sprcrw, can't wait to see it!!
That required much more time and patience than I could afford, so awesome job in doing it all yourself.
