Which JL Sub and Box???
Old Apr 9, 2009 | 12:45 PM
marcolarco52's Avatar
Originally Posted by way2qk4u2c
Whats the difference between
JL 10w3v3 and JL 10w3v2?
Will you notice a huge sound difference?
Originally Posted by pmason718
I would like to know this also
the different is...the v2 is the older version of the sub v3 is the newest version of the sub...maybe some minor/major changes made in it that i dont know i dont have the JL sub but there were some changes made from the v2 to the v3
Old Apr 9, 2009 | 01:09 PM
RegularJoe's Avatar
I know the v3 is taller than the v2. I think the cone is differently shaped too. The v3 also handles a little more power.
Old Apr 9, 2009 | 05:50 PM
ranorris2's Avatar
I went to Cartoys today and bought a JL Audio 10" W3v2 for 80 bucks (those are on clearance now), the specs on it say for a ported box 1-1.5 cu. ft., so I will give this a try in my box now and see how it sounds, and if its bad I will just build a custom box and be done with it.
One more question for you guys, the crossover on the amp i have now isn't working so I need a new amp, I was looking at the JL Audio 250/1v2 amp, what do you guys think, will that be enough power for 1 10" W3?
Or would you guys go JL Audio 300/2v2 for the amp?
Old Apr 10, 2009 | 04:19 PM
7lug's Avatar
Originally Posted by MDK
but I would really recommend a SCS box. Their cheap and you can add plenty of subs and those guys will even tell you what will fit and what won't. Stop wasting money on a quick fix and just do it right the first time.
The SCS box IS a quick fix
Old Apr 10, 2009 | 04:54 PM
JJDH's Avatar
amp
call jl and see what they think. with the 300/2, wire the sub in parallel,=2 ohm load, and bridge at amp.. 250/1 would be only 25watts less per coil, more efficient, wire it the same so ur at 2ohms, just not bridged at amp, mono, cant anyway, so ur making it basically one coil. prolly price or preference, mono amp would be better, 50 watts not noticeable.
Old Apr 10, 2009 | 04:57 PM
JJDH's Avatar
sub
10w3v2 is a dvc....w3v3 is svc
Old Apr 11, 2009 | 07:13 AM
MDK's Avatar
MDK
Short of making one yourself out of fiberglass is about as custom as it's going to get. Sounds like a long term solution to me.
