Help with sub box material!!!
Old Feb 6, 2009 | 02:36 AM
Low_e_Red's Avatar
Originally Posted by jimmyv13
I'm not saying use those exact rings. I'm saying to make something similar out of 3/4" MDF to use as a mounting plate and glue it to the box. It most certainly will not be worse than only having a 3/4" plate. I've seen this procedure done countless times on boxes with 15" subs.
Its not helping much. Because the issue is flex, thats why a double baffle would be required and that added ring wouldnt strengthen it up (if not make it worse.)
