Build
Old Dec 31, 2008 | 06:27 PM
  #31
hen23's Avatar
Originally Posted by jrfonte
local welding supply shop! 1/0 2/0 whatever alot cheaper high strand count, very flexible, extremelly tough jacket, just no pretty colors.
Ummm...had that in my shop. NO. Its not flexible, and compared to Hyperflex its like a metal rod. And it barely comes off the spool at 30 degrees.
Old Dec 31, 2008 | 11:15 PM
  #32
jrfonte's Avatar
Old Jan 1, 2009 | 04:56 AM
  #33
mSaLL150's Avatar
well ok but its still alot cheaper
cheap doesn't always mean better. Look for Quality.
Old Jan 1, 2009 | 06:44 AM
  #34
styxnpicks's Avatar
strand count people
strand count!!!!!!
Old Jan 1, 2009 | 03:40 PM
  #35
Low_e_Red's Avatar
Originally Posted by hen23
Chill out haha. I knew I was gonna get chit for that. Its gettin wrapped up tomorrow. It got dark and I dont have a light on my hood (XL) and the shop has a tractor with no seat on it occupying the bay. Itll happen when I set my gains tomorrow.
1/0 in is for the upgrade to the 2200D. 1200D will only take 4 ga in 4 ga out, which is why I have a reducer. The ground run is all of 3 inches. I could probably run 8 ga and be okay. AQ amps are also 84% efficent FYI, not a whole lot of current draw for the output.
And Low, delete your effing PMs. Id like to buy some Hyperflex for Big 3 project in 2 or so weeks.
3" okay... Ill let it slide then.
I dont mess with PM's. Email me.
Old Jan 1, 2009 | 03:41 PM
  #36
Low_e_Red's Avatar
Originally Posted by styxnpicks
strand count people
strand count!!!!!!
Old Jan 1, 2009 | 04:33 PM
  #37
hen23's Avatar
Um wouldnt really matter either way. Its 4 ga in 4 ga out on the 1200D. Just ran 1/0 to the amp because I plan on tossing a 2200D at these in a bit, see what happens...
But thanks for the leniency!
Old Jan 4, 2009 | 09:34 PM
  #38
hen23's Avatar
Okay so the box take two has begun. Used to be ~1.7 at ~40 Hz, now will be 1.9 after displacements at 31 Hz. If this doesnt get low Im giving up lol.
Started with a clean sheet of MDF and ripped all the pieces on my table saw. Going skiing tomorrow but the box should be done by Tuesday or Wednesday.
Old Jan 5, 2009 | 03:09 AM
  #39
Low_e_Red's Avatar
31Hz can drop to 23.25 Hz. After that it will unload.
Old Jan 5, 2009 | 07:43 AM
  #40
hen23's Avatar
Port fires forward now, and is 40.25 inches as opposed to 19.
Old Jan 6, 2009 | 03:07 AM
  #41
Low_e_Red's Avatar
Thats getting a bit long for a port. Anything over 32-36 starts to develop whistles.
Old Jan 7, 2009 | 11:15 AM
  #42
jrfonte's Avatar
Old Jan 7, 2009 | 11:43 AM
  #43
styxnpicks's Avatar
man you got jipped.... the welding cable has less wire and more jacket...
stick with Knuknconceptz 4Ga which has 2058 strands of 36awg
Old Jan 7, 2009 | 11:49 AM
  #44
jrfonte's Avatar
Old Jan 9, 2009 | 05:42 PM
  #45
hen23's Avatar
A bit long? Thats not the cause of port noise. Port length is a function area and the desired tuning - it could be 400 feet long as long as you have equivalent box volume and port area.
Too little port area causes port noise
Anyways box is done, and it gets really low - 27 Hz note in put on is absolutely absurd
