Amp Recommendation
Old Dec 2, 2008 | 04:16 PM
hen23's Avatar
Amp Recommendation
Scrapped the idea of shallow subs - was taking wayyyyy too long for the BMs, especially with this recent "cone redesign" thing. So I've got a pair of DD 1508s on the way instead. Gonna put them in about 1.9 cubes, tuned somewhere near 35 or 40 Hz. Not real sure about that right now.
Need a good, clean amp putting out around 1-2k at 1 ohm. Stock electrical, but the PSDs have some serious alts and dual batts so hopefully I'll be alright for now.
New or used is fine, and obviously price is an issue. Id like to not spend more than 300, 200 ideally.
Old Dec 2, 2008 | 04:22 PM
styxnpicks's Avatar
autotek mx2000...
1200x1 rms @ 1Ohm can be had pretty cheap on ebay
the Elemental designs Nine.1 is a 1200x1 @ 1Ohm also and is $295 new from their site
Old Dec 2, 2008 | 06:14 PM
mSaLL150's Avatar
Check ebay for the USamps xt2000d or xt4000d. One is 1000 @1ohm and the other is 1500@1ohm. Both can be had between 200-300 bucks brand new on ebay.
Also, if you dont mind getting used, check out the classifieds on DIYMA there are always used high quality amps in good condition going for excellent prices. There was a Sundown SAE1000D going for 240 shipped just the other day.
Old Dec 2, 2008 | 07:39 PM
hen23's Avatar
I can get a RD 1000.1 for about 200 plus shipping. Same board as the SAE1000D if what I hear is correct. Is RD quality stuff? I know the 1000.1 MSRP is like 600.
Edit: The RD is obviously used. And I have ZERO problems with used. Just gotta be small enough to fit under the bench seat of a single cab 350.
Old Dec 2, 2008 | 07:42 PM
hen23's Avatar
Originally Posted by styxnpicks
autotek mx2000...
Thats a nice price right from the manufacturer. That gonna do rated?
Old Dec 2, 2008 | 07:53 PM
styxnpicks's Avatar
not sure I havnt used the nine.1 myself.. Im sure its been used by tons over at ca.com... its fused for 120 amps... so probably lol
Old Dec 2, 2008 | 07:55 PM
hen23's Avatar
Yeah I was just looking over at ca.com at a comparison of the NINE.1 to the AQ1200. The AQ is about 50 cheaper straight from the manufacturer as well, much more efficient, and a bit smaller. But the rated voltage is 14 rather than 12 like the ED...so Im a bit lost here. Which of those 2 would you personally recommend? Or can I not go wrong with any of these choices?
Old Dec 2, 2008 | 08:11 PM
styxnpicks's Avatar
most cars run between 13.8 and 14.4 volts...
Old Dec 2, 2008 | 08:31 PM
hen23's Avatar
Yeah I realized that was a dumb question after I asked it. So with that said, which of those two (ED and AQ) would you recommend?
Old Dec 7, 2008 | 06:20 AM
jrfonte's Avatar
psd voltage dont run over 13 volts you would get more power out of the ed at least mine never has
