Help with wiring speaker with tweets?
its just a cheap 2200w 5-channel Valor i got from a whole sale place dbldistributing.com. wanted to hook up all four doors and a sub with some tweets. i bought four polk audio 5x7's for the doors.
What I've done in the past is use the headunits speaker outputs to power tweeters. A descent headunit will give you about 25w. Just make sure you have a inline filter for the tweeters to block the lows that normally go to the front RCA's. Another option is if your front amp has pass through connections you can use a tiny amp to power some higher power tweeters and use the amps high pass filter.
Polks I think are a bit bright I'd probably look at some silk tweeters to add a bit of depth to the sound.
