Would this work??????
Old Nov 14, 2008 | 08:28 AM
LARABOY's Avatar
Exclamation Would this work??????
I WANT TO KNOW IF THIS WORKS? HAVING A BOX THAT FITS UNDER THE WHOLE REAR SEATS AND HAVE FOUR 10 INCH SUBWOOFER.
WHAT WOULD HAPPEN IF I PUT THE SUBS BACK TO BACK ONE MAGNET FACING ANOTHER WHAT WOULD THIS DO?????
Old Nov 14, 2008 | 08:47 AM
LARABOY's Avatar
I'm using a shallow mount pioneers if that helps any!!
Old Nov 14, 2008 | 09:18 AM
Landon Kolesar's Avatar
No man i dont think it would. The subs would be fighting each other back to back like that. Plus the sub on top would be so muffled by the seat anyway. You always want to down fire your subs when there under the back seat, because the longer the sound wave can travel the better the sound. I think the only way to do this if its really what you want, you need to make individual chambers in your box for each sub.
Good luck!
Old Nov 14, 2008 | 10:28 AM
styxnpicks's Avatar
Good luck!
wow... im not even going to touch that post
you can do it. however I would recommend keeping all the drivers on the same plane if possible be it downfire or upfire. you can run individual chambers for each driver or use a common chamber.
Old Nov 14, 2008 | 10:48 AM
Low_e_Red's Avatar
That design wouldnt work well actually. You are getting close to something called isobaric loading. But if you wanted to really pull the 4 10's off well downfire with the cones facing. Have one recessed into the box normal orientation and the other facing it with the spk wires reversed.
Details and a much more thorough explanation go here:http://mobile.jlaudio.com/support_pages.php?page_id=157
Oh and next time QUIT YELLING!
Old Nov 14, 2008 | 11:05 AM
styxnpicks's Avatar
c'mon low... you know thats not even close to isobaric loading
Old Nov 14, 2008 | 11:10 AM
Low_e_Red's Avatar
Its mag to mag, 4 10's and .... But it gave me a reason to bring up iso.
Old Nov 14, 2008 | 11:49 AM
styxnpicks's Avatar
you know better than to bringup isobaric around here.... it just confuses people more
Old Nov 14, 2008 | 01:14 PM
LARABOY's Avatar
thanks guys so then should I put another [iece between the subs????
Old Nov 15, 2008 | 12:51 AM
Low_e_Red's Avatar
Ehh, true. :o
