SuperCrewSound box...amplifier location??
I'm looking at the supercrewsound box that hold 2 10" subs. I have a supercrew and there is no place to put an amplifier if i get the box that takes up all the space under the seat. For those of you with this box, where did you mount the amplifiers? Thanks in advance for all the help!
Once I remove the back seat to install on the rear wall, about how much room is between the wall and the backseat?? Will the amp easily overheat in that small space?
Hopefully more people will chime in. I have seen this discussion in the forums quite a few times.
First of all, what year is your truck?
NBS - I have mounted 40-50amps back there never a problem. Hell one was a KKR KX1200.1 @ 1 ohm. That was hot as hell but still never a problem.
its an 08 Lariat SuperCrew. I want to put to two 10" Kicker Comp VR's in the supercrewsound.com's underseat box just because I've had those subs before and I love them. I'm still deciding on an amp. You seem to know what your talking about a lot more than me...what sub would you reccomend? Again, thanks for the help. I really appreciate it!
