Installation Questions
Old Aug 10, 2008 | 01:04 PM
Patatoe1's Avatar
Hey guys, I have installed 4 Pioneer speakers into my Focus. I am in the process of installing an amp right now and had some issues.
I won't be changing the head unit it the car. So for getting the signal from the speakers I will be installing a lineout converter behind the dash. Do I need a 2 channel converter or a 4 channel converter?
After the amp is installed I plan on installing an Infinity Basslink in a couple weeks. Will I be able to tap into the rear speakers for a signal to the Basslink?
Old Aug 10, 2008 | 02:49 PM
C. Whammy's Avatar
4 channel would be better because then you would keep your fade adjust. if you get a 2 channel you're also have to get 2 rca splitters
yes, just get another line out converter (2 channel) and use that to get a signal for the sub
so you are either going to need a 4 channel and a 2 channel, or 3 two channel line outs
Old Aug 10, 2008 | 09:23 PM
Patatoe1's Avatar
I was hoping someone could tell me if this setup would be compatible with each other. It is going into a 2008 Focus Sedan.
Amp
http://cgi.ebay.com/KICKER-ZX300-1-3...6.c0.m14.l1318
Sub
http://cgi.ebay.com/RE-AUDIO-SR10D2-...6.c0.m14.l1318
Box
http://www.onlyfactorydirect.net/servlet/Detail?no=28
The only problem I could potentially see is the Sub says it needs 9.25" hole to fit in and the box is 9.125", but I figured I could possibly sand away that 1/8"?
Also installed already in the car are 4 Pioneer TS-A6970R powered by a Sony 4channel amp.
Could anyone offer advice?
Old Aug 10, 2008 | 10:03 PM
Low_e_Red's Avatar
The four channel would definately be better. Is there a stock sub?
Old Aug 12, 2008 | 09:38 PM
Patatoe1's Avatar
No stock sub. Could someone let me know if that setup would work together.
