Build log summary
Old Jun 29, 2008 | 11:41 PM
duece212's Avatar
Build log summary
Figured I'd post this here, had a build log following the progress over on ca.com, here's a summary with some pics. The build started out clean and towards the end I was just slappin stuff in as fast as possible to catch a competition today, unfortunately I missed it by just a few hours. Build is for daily and the occasional bassrace comp. Things will be cleaned up as time goes on:
Kenwood DDX812 (w/sirius/ipod hookup/etc)
Boston Pro 60's
Boston Type-M imaging kit (not installed yet)
AQ HDC318
AQ 2200
Kicker 550.2 for the 60's and imaging kit
Epicenter (not installed yet)
Knu Krystal RCA's
~45ft of Knu Fleks 1/0
2 bulk packs of dynamat
~30ft of SS Damp pro
2 sheets of SS overkill pro (Doors if it fits)
2 sheets of SS luxory liner pro (back wall)
BJfisher box - 5.75 @ 38 with 92sq in of port
Mean Green 200amp alt
Yellowtop front, two powersonic batts in the back (HC600 clones)
Custom metal frame in the extended cab boarded up and carpeted
The truck this all is going in:
Backseat ripped out:
Metal frame I have boards cut for, just need to carpet them:
Molex's with wire, molex's eat moose ****:
Old Jun 29, 2008 | 11:42 PM
duece212's Avatar
Deadening on the outside doorskin:
Door deadened in and out with a layer of secondskin overkill pro on top. I'd suggest using the regular overkill instead of the pro, it was a pita to get the door panel back on:
When your really white you shouldn't stand outside in sandals all day deadening a truck without sunscreen:
Tweet and Mid in each door:
Old Jun 29, 2008 | 11:43 PM
duece212's Avatar
Backwall stripped:
Used to be a cab vent here:
Roof flashing cut to cover:
Metal matted on both sides and screwed in place:
Old Jun 29, 2008 | 11:45 PM
duece212's Avatar
While working on the truck a bird decided to fly over and crap on my sill plate....stupid bird!
Had some leftover overkill pro so it got rammed in every orifice in the back:
Backwall all shiny with 1 to 2 layers of mat on it:
And last a layer of overkill on the backwall, if the overkill works 1/2 as good as it looks it will be awesome. Really like applying the stuff, before the foil tape on the seems it almost looked to good to cover up:
Old Jun 29, 2008 | 11:46 PM
duece212's Avatar
Metal frame for the back boarded/carpeted
Frame/boards mounted in the truck:
Sub in the truck:
Amps between the backwall and back of the box...dig on the hot pink remote wire:
Old Jun 29, 2008 | 11:50 PM
duece212's Avatar
From outside the truck:
Well thats all the pics I have, shoulda took more along the way but got busy and didn't stop to grab the cam. Unfortunately I missed the comp today so no numbers on it.
The setup gets downright loud, the boston tweets are a little harsh but after some tweaking hopefully that will help. Only deadened the front doors and backwall and it is suprisingly quiet outside for 200+w per door on the mids and 2200w on the sub. Its also nice and quiet inside cruising on the highway now. Have to admit the truck was pretty quiet inside from the factory though. I will be doing the rear doors in the next week or two. The deadening was well worth the effort.
Old Jun 29, 2008 | 11:58 PM
Bartak1's Avatar
Lookin good. You def. got a lot of space back there without that seat in there.
Looking to hit a certian number, or just do whatever you can do?
Old Jun 30, 2008 | 12:11 AM
duece212's Avatar
Oh yeah, its amazing the space you get when you take out the backseat. Luckily for bassrace you don't have to be loud, I'll be shooting for the 139.9 class. Hopefully it will do low 40's on music. Wish I would have gotten this done a few hours earlier, then I could have got on a mic at the show today.
I have another hdc3 motor in the garage, toying with adding another 18 just for shows. The single 18 is more than enough to give me a headache in short time. I'm getting older though so the "if its too loud your too old" thing must be true
Old Jul 28, 2008 | 08:22 PM
duece212's Avatar
Well I change stuff too often...old sub is already torn out and my new sub just showed up, Incriminator Audio's new 21" death penalty
Here it is by a dayton ref 8 for comparison...the thing is ridiculously big:
Old Jul 28, 2008 | 08:46 PM
C. Whammy's Avatar
holy shat i want one of those!
and only 1500W rms? (at least thats what it says on the site) i can do that!
Old Jul 28, 2008 | 09:11 PM
mSaLL150's Avatar
I wonder if that thing has any kind of SQ. Loud as chit im sure.
DId you mount the mid straight to that adapter plate, or did you put some foam/cardboard/deadener between it? Sometimes those things can rattle if its mounted straight to it.
Old Jul 28, 2008 | 09:13 PM
duece212's Avatar
I'm only going to be giving it about 2000w. Probably won't be any louder than my last setup, but it will look good for shows.
Supposedly the smaller versions of the DP aren't supposed to sound tpo bad, no reviews on the 21 yet though. Pretty obvious with my last sub choice though, not too worried about how it sounds.
Old Jul 28, 2008 | 09:16 PM
mSaLL150's Avatar
Yeah. Looks good, this makes me super anxious. I get a fat paycheck this week, which means i get to order most of my new system by friday. I am stoked.
Old Jul 28, 2008 | 09:18 PM
duece212's Avatar
There is some gasketing foam between the mid and the mounting plate. Was done in a hurry though trying to get ready for a show. I will probably be making some mdf baffles for them in the near future.
Old Jul 28, 2008 | 09:21 PM
Bartak1's Avatar
Thats a HUUUGE BITSH.
Thing looks dang near 21 inches deep too
Very cool though. Curious, what size of box are you going to run that in?
