Audio Set-up
Old Jul 3, 2008 | 03:30 PM
Low_e_Red's Avatar
Yes, That is what I am saying.
KS - 2 sets 6.5" in the front doors, 1 set in KPs and 1 set in rear doors.
SS/RS - 2 Sets of the 6.5" in the front doors and the KKR 04SSMB8 in the KP.
SS or RS depending on available $$
Old Jul 9, 2008 | 06:31 AM
DeviousZen's Avatar
Ok I think I will go with 1 set of SS65.2 in front doors SSMB8 in Kick Panels and 1 Set SS65.2 in rear doors!
Old Jul 9, 2008 | 08:20 AM
Low_e_Red's Avatar
Make two sets fit in the front doors. NO need for Rear Fill. It just pulls the sound backward.
Old Jul 9, 2008 | 08:52 AM
styxnpicks's Avatar
rear fill sucks
Old Jul 9, 2008 | 02:43 PM
DeviousZen's Avatar
Even if I put the SSMB8s in the rear will it still pull sound backwards? If it does I should just get the door panels custom made right! Or glassed as you guys do it out there!
Old Jul 10, 2008 | 10:08 AM
Low_e_Red's Avatar
I was trying to say have the 2 6.5" mounted in the door at the bottom. There should be enough room for both 6.5" in the little gray panel. Then a glassed KP for a 8"
Old Jul 10, 2008 | 10:20 AM
DeviousZen's Avatar
Yeah I knew what you were saying there! I was just wondering what else to do! I saw a kick panel enclosure for the 6.5s so I was gonna do 1 in door and 1 in kick panel if it was reccomended to put the 8" in the rear! But as I can tell so far not alot of fans of rear fill! Plus I have never owned a truck first one and so no rear fill is a new concept to me! Hopin that if I go that route it is not too different and I will like it!
Old Jul 10, 2008 | 12:55 PM
Low_e_Red's Avatar
I didnt think I would like it at first. But i found its so much better for SQ.
Old Jul 12, 2008 | 11:57 AM
DeviousZen's Avatar
What about turning my rear seat into a sub box? Or just custom made box under the rear seat with a seat lift.
Old Jul 12, 2008 | 02:40 PM
Low_e_Red's Avatar
Bass below 80hz is omni-directional. So a sub in the back is fine.
Old Jul 15, 2008 | 08:29 PM
DeviousZen's Avatar
Thx alot I will keep u guys updated on the truck audio as I get it 2gether!
Old Jul 16, 2008 | 11:37 AM
DeviousZen's Avatar
I have another question! Should I also dabble with the Big 3 Upgrade and a Audio Control Matrix for more amp output?
Old Jul 16, 2008 | 03:13 PM
Low_e_Red's Avatar
Big 3 is MANDATORY!
Audiocontrol Matrix is up to you.
