2001 back wall rattle w/ subs
so a while back I got two 10" subs put in on the back wall of my reg. cab.
Now, i'm getting a rattle when the bass is really thumpin'. seems to be coming from the plastic trim below the windshield, or right above the red line in the picture:
if i just bought a small pack of dynamat and stuff it behind the trim (there is a lot of space between the trim and the actual wall, kinda cheaply put on) would you think the rattle would stop? Its driving me crazy, and I can only put the bass 1/2 way or it'll really shake. let me know what you think
The back wall has a lot of loose overlaping plastic that CAN rattle like a mother. Any type of sound deadener, along with felt between plastic/metal, ductape, and some eggcrate foam can go a long way to get rid of rattles
Are you sure its not the cab vents on the back wall? With any decent amount of bass they will just flutter and make the most Godawful annoying sound. If you get under the truck with the stereo turned up and stick your head around the area between the box and the cab you will be able to hear it.
thanks for the compliments man
