ohms and speakers
Old May 4, 2008 | 09:26 PM
306stang's Avatar
ohms and speakers
redoin my system and don't know which sub to buy.
going with a kicker 750.1 and the specs are . . .
# RMS Power: 750W x 1 @ 2 ohms
# RMS Power: 375W x 1 @ 4 ohms
i want to go with the shallow mount cvt 12's. they come in a 2 ohm and 4 ohm model.
i figure that it really depends on the wiring but which model would i need.
Old May 4, 2008 | 09:59 PM
GJ Screw's Avatar
Get the 4 ohm, and wire it in parralel it will drop it to a 2 ohm load. Would be perfect for those subs..
Jon
Old May 4, 2008 | 10:28 PM
1bad86vmax's Avatar
Wiring 2 4ohm drivers in series would give you an 8 ohm load . You would want to wire them in parallel for a 2 ohm load .
Old May 4, 2008 | 11:38 PM
GJ Screw's Avatar
oops, thats what I ment..
Jon
Old May 7, 2008 | 09:32 PM
FoMoCoFan17's Avatar
I've been pondering this ohm thing myself.
I'd like to do something similar. The 750.1 and one CVT shallow mount. The 2 ohm would be right for me? Right?
Old May 7, 2008 | 09:51 PM
1bad86vmax's Avatar
If your only buying one sub , buy a dual 4 ohm sub . Wire the coils in parallel for a 2 Ohm load .
Old May 10, 2008 | 06:10 PM
306stang's Avatar
one ten or one twelve??
Old May 10, 2008 | 10:20 PM
kansasflareside's Avatar
For any one wondering about how to wire their dual coil subs, use page 17&18 this link for help. Its an old L7 manual, but the wiring is the same for all dual coils.
LINK
Old May 11, 2008 | 11:55 AM
12" - The shallow mount looks like it's single voice coil.
Now i'm thinking I should step up to a single L5 or L7 4ohm with either the 750.1 or 1000.1.
How does that sound?:o
Old May 11, 2008 | 08:10 PM
1bad86vmax's Avatar
If your only using 1 sub , I would recommend getting a 4 Ohm Dual voice coil sub . Wire the coils in parallel for a 2 Ohm load . If you use a 4 Ohm single voice coil sub , your not going to get the full power out of your amp , running it 4 Ohm mono .
